-   -   Confession Time (http://www.diychatroom.com/f18/confession-time-157832/)
ddawg16 09-24-2012 11:32 AM
Confession Time
I must confess my sins......
Yesterday I was working on the wireing on the side of the house.....all the stucco was pulled off and I was relocating the outside light over about a foot....while I was at it, I was extending the ckt over to the corner so I could install an outlet up high and in the corner to be used for a camera and for xmas lights.
While chasing the wireing...I came across a line that was wire nutted and just shoved up into the rafters........
I did it....12 years ago when I was redoing the kitchen....(at least it was taped). The wire was too short to reach a new light so I took the shortcut.
There...I confessed.....
And I fixed it....since I had the side of the house open, I pulled it all out and ran a new line doing it right. I lucked out in being able to pull part of the new wire through a wall....the new romex is sligtly smaller than the old black tar covered stuff of 60 years ago....so once it pulled through the staple in the wall...it went pretty easy. Which means the new romex is stapled.
On another positive note....I basically rewired everything on that side....the switch box now has a neutral in it...
Julius793 09-24-2012 01:48 PM
Well at least you confessed before the high holidays now you can be forgiven :-)
techpappy 09-24-2012 02:23 PM
do you realize all the anguish you have caused!! Now we all feel compelled to "confess" AND FIX...our sins!!!
Of course I don't have any!
ddawg16 09-24-2012 07:08 PM
Ok....so you are a habitual liar......:thumbsup:
raylo32 09-24-2012 07:14 PM
If you still have it open consider also running an ethernet cable to the location where you want the camera. Power Over Ethernet ip cameras are the way to go these days. You don't need no stinkin' power cable....
ddawg16 09-24-2012 07:19 PM
Still open.....but....getting the ethernet to that spot will not be easy....the camera I'm using is wireless.....works well...even has audio.....
As soon as the construction is done....I'll be adding a couple of wired cameras in key spots. This paticular spot is more for watching the kids in front of the house.....so wireless is fine.
