Conduits Stubbed Too Close Together - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 01:22 PM   #16
Experienced
Jackofall1's Avatar
Originally Posted by Mobetta View Post
JV, I could easily bend conduits to fit. I don't want to do it that way because
I would have stand the box off the wall and it would not look good.
I want a nice clean box mounted over the conduits and I'm trying to get
some opinions on whether or not it would be code compliant to do it that way. Got anything worthwhile to contribute?
That was a pretty crappy thing to say to someone that is trying to offer up an idea.
Mark
Old 03-06-2011, 01:29 PM   #17
Maybe I took it the wrong way but it's obvious that you can bend conduits to fit. Wasn't expecting
someone to be bragging about being capable of bending conduit. The code is subject to interpretation.
Looking for someone who can nail down the original question with an irrefutable code reference and not some cocky
B.S. So far nobody has.
I do appreciate your feedback.
Mobetta is offline   Reply With Quote
Old 03-06-2011, 02:05 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I give. While that section is specifically directed to electrical continuity, it does appear to address itself to other matters as well. Although I had been chastised many times for utilizing a titled section for anything other than what the title directs itself to, it does appear to require a mechanical connection (I think Cowboys's comment of "bolt" was not intended to be a exact statement but more of a paraphrased commentary).
I will still stick by: I have done exactly what you are suggesting many times and have never had an inspector knock it down. You had the correct idea before when you said you were going to ask your local inspector. I think that is the only thing that is really going to matter.
Old 03-06-2011, 02:15 PM   #19
I like the way yer thinkin! Thanks Nap! I'll let you know what they say.
How to get double front doors to close tight Advising Elf Windows and Doors 31 12-30-2012 11:09 AM
Garage Door Won't Close handy man88 Building & Construction 13 09-30-2010 10:47 AM
Ice dispenser flapper door won't close - Whirlpool Side By Side homerb Appliances 2 05-20-2010 07:54 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
