Conduit Vs Direct Wire....why - Electrical - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 03:53 PM   #1
Rewards Points: 91
Conduit vs Direct Wire....why
Some parts of the USA require the use of conduit and others don't. Why the differences across the country? Is one superior over the other or just more work for electricians and less work for DIY'ers?
George6488 is offline   Reply With Quote
Old 02-06-2011, 04:09 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Some areas have very strong unions and corrupt politicians.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
mpoulton (02-08-2011), Speedy Petey (02-06-2011)
Old 02-06-2011, 04:18 PM   #3
Rewards Points: 506
DIYers can use conduit too!
jlmran is offline   Reply With Quote
The Following User Says Thank You to jlmran For This Useful Post:
nap (02-06-2011)
Old 02-06-2011, 04:48 PM   #4
A "Handy Husband"
rjniles's Avatar
I was not trying to say that there are not legitimate reasons and uses for conduit.
My point was the requirement to use conduit in residential wiring instead of metal or plastic sheathed cables.
Old 02-06-2011, 05:07 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
your point as I read it was there is no reason to use it other than those damn unions and the crooked politicians (I guess they must be in bed with the unions).
Can you say that conduit is not a superior system? If it is, what is wrong with some area that requires the electrical installations meet the highest standards rather than accepting a functional yet inferior system?
Old 02-06-2011, 05:40 PM   #6
A "Handy Husband"
rjniles's Avatar
Your words not mine (but I do agree with you).
Certainly there are valid reasons for use of conduit, but metal or plastic sheathed cable has been a proven product for many years. Economics is a factor and without a doubt has priced people out of market when politicians require residential wiring in conuit installed by a fraternal group of electricians. The same fraternal group who donated $$$ to his reelection campaign.
By your reasoning: If the best possible should be the requirement for all:
Hard metal conduit is better than metal tubing (EMT)
Threaded joints are better than compression fittings.
All houses must be wires with rigid metal conduit with threaded fitting.
It does not matter what it costs it is the best and safest.
Old 02-06-2011, 07:31 PM   #7
Master Electrician
Rewards Points: 3,870
Metallic conduit has been required in the Chicago area a long, long time before certain people were elected. Someone in SC should be careful about accusing others of having corrupt politicians.
brric is online now   Reply With Quote
Old 02-06-2011, 07:49 PM   #8
nap
You talking to me?
nap's Avatar
Certainly there are valid reasons for use of conduit, but metal or plastic sheathed cable has been a proven product for many years. Economics is a factor and without a doubt has priced people out of market when politicians require residential wiring in conuit installed by a fraternal group of electricians. The same fraternal group who donated $$$ to his reelection campaign..
to whose re-election campaign? Conduit has been required for a long time in Chicago. They have had 18 different mayors since 1900. I don't know when Chicago first started requiring conduit but I am sure it wasn't enacted after RM Daley has been elected so now there must be multiple crooked mayors allowing this horrible condition to continue.
why don't you find out when conduit was first required in Chicago residential buildings so we know when the corruption in their government started.
Old 02-06-2011, 08:14 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Conduit is certainly a superior system, but there is a point where superior becomes absurd.
IMO requiring ALL conduit with limited sections of metallic flex, in a typical residential installation, is 100% certifiably absurd!
Why not require gold conductors that are two sizes oversized to prevent overheated circuits? Hell, the NEC is a minimum standard, right?
Speedy Petey is online now   Reply With Quote
Old 02-06-2011, 08:25 PM   #10
Rewards Points: 506
Originally Posted by Speedy Petey View Post
Conduit is certainly a superior system...
Superior by what standard or metric? NM cable could be superior to conduit, depending on your paradigm or needs.
Old 02-06-2011, 08:29 PM   #11
Superior in terms of durability and replacement of conductors.
NOT superior in terms of changes and additions as some would suggest.
Old 02-06-2011, 08:30 PM   #12
nap
You talking to me?
nap's Avatar
I do a lot of things above and beyond code requirements because I believe the code doesn't go far enough. Without knowing why Chicago requires conduit, it is very difficult to argue their reasoning is flawed.
Heck, the code doesn't even require upsizing conductors for voltage drop but every electrician I know does it. So, are we wrong for upsizing conductors?
Unless somebody can find when conduit was first required (in Chicago code) and some discussion as to why, I don't think an answer will ever be realized here.
Old 02-06-2011, 08:33 PM   #13
nap
You talking to me?
nap's Avatar
really? Please list some claim NM has as being superior to conduit and separate conductors with any of a dozen different types of insulation.
Old 02-06-2011, 08:57 PM   #14
Registered User
Termite's Avatar
Everyone is free to state their opinion on the issue here, but please refrain from jumping on those that don't agree with your opinion. You can make your case more effectively by stating the facts as opposed to challenging others.
Old 02-06-2011, 09:10 PM   #15
Rewards Points: 506
Cost? Ease of use? Conductors are already placed in the sheath, versus pulling conductors through a pipe? NM can be used with plastic boxes? NM doesn't have to look pretty because its always hidden? With NM you don't have to make bends at various degrees? An entire cable can be cut with a pair of dikes, vs. cutting conduit which requires a saw or tubing cutter? Conduit has to be measured precisely where NM only has to be close.
All I was saying was that 'superior' was loosely defined.
wire in conduit silver 11 Electrical 8 04-11-2010 08:20 PM
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 11:41 AM
When wire needs to be outdoor / direct burial rated jamiedolan Electrical 23 02-25-2009 11:46 AM
Direct burial vs. conduit? vsheetz Electrical 15 01-05-2009 06:39 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
