Old 05-28-2012, 09:10 AM   #1
Conduit vibration when AC unit kicked on.
First day of running our air conditioner. When the air conditioner turned on a loud buzz and vibration in the conduit occurred in a pulsing rhythm fast at first then slowed and the stopped. Happened only once. Has not happened since. Additionally the power to our tv went out momentarily but did not trip the breaker. it appears that the conduit leading to the AC unit also contains the lines for the outlet for the TV. Finally ac unit is a rheem and is over 20 years old. Thoughts?
martinMP# is offline   Reply With Quote
Old 05-28-2012, 09:23 AM   #2
Licensed Electrician
k_buz's Avatar
I would have your compressor looked at. It sounds like the compressor might be going bad and drawing more on start up.
Old 05-29-2012, 04:49 PM   #3
k buz is usually right, and I wouldn't second guess him, but, if it was the first time of the season, and it doesn't reoccur, maybe ok?
jb64 is offline   Reply With Quote
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 09:02 PM
Glacier on my AC Unit? Where's Al Gore? livinginthepark HVAC 10 07-13-2010 04:59 PM
What is the price difference between a 2.5 ton unit and a 3 ton unit? Leoskee Off Topic 2 03-27-2010 08:13 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 06:25 PM
