Old 08-19-2010, 10:25 AM   #1
Conduit up side of house
What is typically done to rewire an old house as far as the upstairs is concerned? Are all the branch circuits brought up individually (using romex) into the attic through the interior walls or would it be easier/cheaper to run conduit up the side of the house? If you run it in the interior walls, how do you minimize the drywall damage? If anyone can point me to a site with tips/tricks for rewires, preferably with pics so i can see how the pros do this, I'd greatly appreciate it!
PhillyRyan is offline   Reply With Quote
Old 08-19-2010, 10:57 AM   #2
Licensed electrician
Whether the cables are fished or run on the exterior depends on the construction of the house. Often times older homes have spaces next to plumbing where the wires can be fished. Balloon framed homes have a chase from the attic to the basement between the stud bays.
Old 08-19-2010, 12:48 PM   #3
joed's Avatar
The last thing I would do is run wires up the outside of the house. I think it just looks very unprofessional.
Find a way fish them even if it means cutting holes in the walls.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 08-19-2010, 01:47 PM   #4
Xtreme DIY'r
I have 2 circuits that went up thru a closet
Rest of the circuits went up near the chimney
---chase where I could route wires
I would never run counduit up the side of a house
Some people run a small sub panel to the 2nd floor
Then run circuits from that
All depends upon the house, number of circuits needed etc
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 06:56 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 05:47 PM
Any issues with connecting gutters form one side of house to other creamaster Roofing 1 11-02-2009 09:57 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 09:48 AM
