Conduit Type - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2011, 12:21 PM   #1
conduit type
I am wiring a panel and gave the thhn #6 ran thru pvc conduit but the last 6 feet of the run needs to be flex conduit due to the way it needs to be ran thru the wall. So I see there are metal and "rubber" types of conduit. It's for my house and never actually leaves the original structure (not a detached garage). What type would you recommend? It's ran as 6-6-6-10 thhn the last 6 feet takes me from pvc to the subpanel box. The existing conduit is 1" with a total of 3 90's. Plus do I need to put a pull point in there as well with there being 3 90s before the flex conversion?
kenmore is offline   Reply With Quote
Old 07-13-2011, 02:35 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
Use carflex(plastic flex).
3 90's are fine.
6 6 6 10 is fine also.
Old 07-13-2011, 07:32 PM   #3
Sparky
Rewards Points: 510
you have to count the bends in the flex aswell, your inspector may or may not require you to put a pull box in-between the PVC and carflex
Techy is offline   Reply With Quote
Old 07-13-2011, 07:41 PM   #4
Missouri Bound's Avatar
Installing a pull box will make that transition to the flex much easier.
Working with PVC Conduit jasonnewyork Electrical 13 07-23-2010 12:38 PM
Water in conduit MYSTERY feign3 Electrical 4 03-14-2010 08:17 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Conduit Fill & Ampacity capndave Electrical 37 03-26-2008 02:16 PM
