Old 09-04-2012, 03:55 PM   #1
Conduit transition - water
I have 2" PVC conduit leading up to the house. I have to transition to metal conduit. Not sure if that should be EMT or rigid for a residential house but that's another matter. What gives me the willies is the transition. It doesn't seem to be water tight and yet it is supposed to take place underground. When a good rain comes along water will get in through the transition and into the conduit, right? Once water goes in there, it is dark and underground. No telling if/when it will dry out.
jackwashere is offline   Reply With Quote
Old 09-04-2012, 04:01 PM   #2
Electrical Contractor
There is nothing you can do to keep the water out anyway.
An underground conduit will collect water just by condensation.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 09-04-2012, 06:01 PM   #3
Semi-Pro Electro-Geek
Underground conduits are always full of water. It's expected. Why transition to metal underground? Why not just use Sch. 80 PVC?
mpoulton is offline   Reply With Quote
Old 09-04-2012, 06:45 PM   #4
Other way around. I'm transitioning to metal above ground. PVC Sch. 80 underground. It's code supposedly. Not sure if that can be EMT or does it have to be rigid.
Old 09-04-2012, 07:31 PM   #5
Why can't you remain with PVC?
hammerlane is offline   Reply With Quote
Old 09-05-2012, 04:22 PM   #6
I would love to. Only I heard that county code requires metal above ground. Also there is the issue of sunlight over time. The sun makes plastic brittle over a longer period of time.
Old 09-05-2012, 04:42 PM   #7
kevinp22's Avatar
Might want to check that code requirement.
Gray PVC around here is actually stamped "non metallic conduit, schedule X, sunlight resistant, approved for above ground and underground..."
kevinp22 is offline   Reply With Quote
Old 09-05-2012, 06:09 PM   #8
I meant why make the transition underground? Run PVC up above grade before changing to metal, if you change to metal at all. Check the code. The NEC certainly doesn't have a problem with this.
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 08:14 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
