Old 02-03-2013, 07:34 PM   #1
Conduit through jpist
We are thinking of leaving our basement to be exposed joist. Right now the conduit is below the joists for the basic light fixtures. Can you drill through the joist to recess the conduit higher in the joist or does it have to stay below the joist? If possible we'd like to have the conduit not stick out below the joist, but I am sure what is the rules.
bryanp22 is offline   Reply With Quote
Old 02-03-2013, 07:59 PM   #2
MarginallyQualified
Something tells me you're in Chicago.
In principle... sure you CAN drill through.
But there are at least as many rules about that as the wiring itself.
If it were my house and my wife came up with this notion....
I'd think about the room as a whole and the layout of the conduit.
Where you *must* run conduit "against the grain" do so at the ends of the room where it is less intrusive or obvious. Where you can get away with it (or will go to some trouble to allow for)... tuck the conduit up into the joist bays.
ps: Greenfield is NOT cheating.
Old 02-03-2013, 08:03 PM   #3
According to the 2006 International Residential Code (IRC) the maximum diameter hole that you can drill in a solid wood joist is 1/3 the ACTUAL depth of the joist. The code also says that holes have to be at least 2" from the edge of a joist. So if your joist is 5-1/2", the maximum size hole would be 1-1/2" if it was centered in the joist. If the joists are slightly deeper than 5-1/2", the hole can be slightly larger.
It's done all the time.
Small holes for just conduit will be a none issue.
Old 02-03-2013, 08:29 PM   #4
I'm in milwaukee. Our house was built in the 50s ad must have at least 2x10s for joists I can measure when I'm home. So normally people drill through to fill the metal conduit?
Old 02-03-2013, 08:31 PM   #5
Licensed Electrician
k_buz's Avatar
Homeowners are not allowed to do their own electrical work in Milwaukee.
Not a fan of the new layout.
k_buz is online now   Reply With Quote
Old 02-03-2013, 08:39 PM   #6
Well it's a suburb not the city. Just milwaukee area.
Old 02-03-2013, 08:43 PM   #7
k_buz's Avatar
Nowhere in SE WI is it legal to do your own electrical work. You can't even pull a permit without a Master's license.
Old 02-03-2013, 09:53 PM   #8
I'm fine hiring an electrician just trying to visualize if the conduit can be moved to in the joist or if it has to stay below. It will impact our lighting decision.
Old 02-03-2013, 09:58 PM   #9
k_buz's Avatar
If the piping has to be either replaced or removed, this will be quite expensive. The conduit can be thru the joists, but it will be time consuming. You know what they say, time=$$
Old 02-03-2013, 10:08 PM   #10
Ca be worth it. Our basement doesn't have much height so we are thinking exposed ceiling with track lighting. We need all the height we can get so having track lighting recess a bit will help with overall height.
Old 02-03-2013, 10:37 PM   #11
Is conduit required in SE Wisconsin?
Old 02-03-2013, 10:43 PM   #12
k_buz's Avatar
Nope. It was for a long time in Shorewood, but not anymore.
Old 02-03-2013, 11:41 PM   #13
Missouri Bound's Avatar
In my opinion you may be cheaper installing a dropped ceiling. There are several nice options available, including wood. And THAT is a do it yourself project.
Do you want it your way or the right way?
Old 02-03-2013, 11:48 PM   #14
Not enough height to do that. My ceiling is maybe 6 feet 8 inches. We want to keep a treadmill in the basement and I barely have a couple inches above me head now when using it.
Old 02-03-2013, 11:55 PM   #15
" Euro " electrician
frenchelectrican's Avatar
For the Northeast area the home owner are allowed to do the own wiring as long they are the owner of the home but only one major gotcha is that the homeowners can NOT change the panel box themself. ditto with meter socket that is complety off limit to homeowner that was in effect 3 years back so that useally stop them in the tracks for safety issue.
Merci,
Marc
Using 2" PVC electrical conduit RonLNY Electrical 7 01-06-2013 11:34 PM
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 09:02 PM
What conduit should I use? mulltron Electrical 6 07-12-2011 02:34 AM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
