Conduit Through Air Shaft(exhaust Vent) - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2006, 10:19 PM   #1
cah
conduit through air shaft(exhaust vent)
I need to run conduit from the basement to the roof of an old 3 story brick building.
Would it be against code to run the conduit through a air shaft that runs from 1st floor to the roof.
The air shaft is used for the bathroon exhaust vents and for the cook stove hood vents
This is residental property. The temperature in the air shaft sould be less than 80 to 90 degs.
What about PVC sch40 , what is the temperature rating?
This air shaft is about 2 ft wide and 6 inches deep, sheet metal lined
cah is offline   Reply With Quote
Old 02-06-2006, 05:42 PM   #2
joed's Avatar
Rewards Points: 13,728
As long as you not running in the vent pipes then you are OK. Beside the vent pipes is good.
Old 02-12-2006, 07:25 AM   #3
sub-contractor
I would first chec and see if the attic has a light installed. If there is one. I would try to see if it is possible to
pull new wires through the runs leading to the attic adding your new circuit. then branch your new run
from there.
This isn't always possible, but if it is it sure beats trying to fish conduit through 3 stories of an exhaust vent. if you do decide to go through the vent(which would never pass code here in Chicago) I definately suggest making any holes air tight and using compression couplings.
Aceinstaller is offline   Reply With Quote
loop vent or auto-vent amakarevic Plumbing 4 08-21-2007 12:28 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 08:32 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 12:08 AM
