Conduit Size Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2007, 01:12 PM   #1
Conduit Size needed
I need to know how many Cat 6 cables can I get inside a 1 1/2 inc pipe? Or what size of conduit do I need to install (12) Cat 6 cables into? Thanks guys
helpless handyman is offline   Reply With Quote
Old 11-09-2007, 02:07 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Try here http://www.lanshack.com/DesigningConduitRuns.aspx
Only thing I'll add is you need to keep your bends to less than NEC requirements,... cat cables will not take the pulling stress that electrical cables will.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 11-10-2007, 02:36 PM   #3
Union Electrician
goose134's Avatar
It also depends on what kind of cat 6. We just did a job with Cat 6a for voice and date. You can only get four of them into a 1 ".
goose134 is offline   Reply With Quote
Old 11-11-2007, 09:41 AM   #4
Here's what you need to figure that out....
OD - outside diameter - of your cat6 cabling. Heres the rule - you can put up to a 50% fill of your conduit with cabling. So...
(Cable Qty. * OD)/Conduit Inside Diameter.
If you have runs longer than 90ft, I'd recommend a pull box too. - makes your life easier.
CuCullin is offline   Reply With Quote
Old 11-11-2007, 11:17 AM   #5
Licensed electrician
Rewards Points: 1,892
[quote=CuCullin;73109]Here's what you need to figure that out....
quote]
Could you please quote this rule? Where is it found?
Old 11-11-2007, 06:47 PM   #6
Union Electrician
goose134's Avatar
I think he may be referring to a BICSI standard. You can do a standard conductor fill calc. for these as well. In this case you'd use the ID measurement of your raceway and the OD of your cable to determine the conduit fill.
Old 11-12-2007, 07:00 AM   #7
Yup! Sorry, I leave things like that out sometimes You can a solutely use a regular conduit fill calc - the reason for the standard 50% fill though is the requirements of much low voltage data cabling (6/6a/6e much more so) are quite stringent to maintain the highest data rates with regards to bend radius, potential for crimping, etc. On the other side of things, leaving some room allows additional and replacement cabling to be much easier later, where you likely still won't pinch crucial wiring.
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Conduit issues - help needed nymackem Electrical 19 11-05-2007 06:45 AM
ceiling joist size - 2x4 or 2x6 needed? bigdaddy352 Building & Construction 9 08-21-2007 12:02 AM
conduit size and NEC stagger19 Electrical 4 08-20-2006 09:44 AM
Size of laminate layout before t-joints are needed wingman Flooring 1 06-22-2006 09:42 PM
