Conduit Size For 2-2-2-4 - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 04:29 AM   #1
conduit size for 2-2-2-4
i am running 125 feet of 2-2-2-4 quad urd. 55' is under ground and the remaining will be straped to the joist under my house untill it reaches where my main 200amp panel is. Should I run the wire in a conduit when it comes out of the ground under neath my house? If so, what size PVC should I use?
Uhila is offline   Reply With Quote
Old 10-08-2011, 05:03 AM   #2
Master Electrician
Rewards Points: 3,918
URD is not a code compliant wiring method once you enter the structure.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Uhila01 (10-08-2011)
Old 10-08-2011, 05:23 AM   #3
what should I do then.... Bury it under the house then change to some other wire before entering the main service?
Uhila01 is offline   Reply With Quote
Old 10-08-2011, 06:44 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,972
That said, I don't think anyone has EVER failed an inspection because of it.
Just sayin'.
Old 10-08-2011, 11:29 AM   #5
Sparky
Rewards Points: 510
a lot of URD Is dual rated, as another type or wire that is allowed inside.
Techy is offline   Reply With Quote
Old 10-08-2011, 12:08 PM   #6
Licensed electrician
Rewards Points: 1,764
I would think ti would be easier to pull individual conductors over the quadplexed cable.
What conduit should I use? mulltron Electrical 6 07-12-2011 01:34 AM
Conduit Size Believer Electrical 1 07-11-2011 03:19 PM
wire size for conduit run WDR Electrical 25 08-07-2010 10:38 AM
is UG conduit size change legal? krazni Electrical 1 07-13-2010 02:17 PM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 07:43 PM
