Conduit Size - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 07:49 AM   #1
Conduit Size
What size conduit should I use to run 220 feet of 2-2-2-4 URD? Thanks.
Believer is offline   Reply With Quote
Old 09-22-2011, 09:45 AM   #2
Licensed electrician
Rewards Points: 1,024
URD is typically used in a direct burial application.
Old 09-22-2011, 10:53 AM   #3
Code05's Avatar
Rewards Points: 1,104
Also 2-2-2-4 AL is too small for a 100 amp subpanel.
Code05 is offline   Reply With Quote
Old 09-22-2011, 12:42 PM   #4
90 amp, correct?
Old 09-22-2011, 12:48 PM   #5
Code05's Avatar
Assuming this a feeder for a sub panel, #2 AL is only rated for 75 amps.
Old 09-22-2011, 12:50 PM   #6
Code05's Avatar
Next standard breaker size is 80 amps.
Old 09-22-2011, 01:06 PM   #7
Yes, it's a feeder to sub panel.
Old 09-22-2011, 01:10 PM   #8
Code05's Avatar
Did you buy the wire already?
What conduit should I use? mulltron Electrical 6 07-12-2011 02:34 AM
Conduit Size Believer Electrical 1 07-11-2011 04:19 PM
wire size for conduit run WDR Electrical 25 08-07-2010 11:38 AM
is UG conduit size change legal? krazni Electrical 1 07-13-2010 03:17 PM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 08:43 PM
