Conduit Size - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 02:21 PM   #1
Conduit Size
I need to run just a few feet of copper wire from a disconnect to a main lug. I Wii go down out of the disconnect underground only two feet horizontally then up then into the back of the main lug. My question is what size conduit should I use? I'm running 200 amps. Guess another question is can I run the conduit above ground?
Believer is offline   Reply With Quote
Old 07-11-2011, 04:19 PM   #2
Electrical Contractor
kbsparky's Avatar
2" PVC conduit would give plenty of room. We have even used 1" on occasion when space was tight, and 2" would not fit. #2/0 copper wires are acceptable for a residential 200 Amp service/feeder. You are not required to bury the conduit.
-KB
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 01:09 PM
wire size for conduit run WDR Electrical 25 08-07-2010 11:38 AM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
is UG conduit size change legal? krazni Electrical 1 07-13-2010 03:17 PM
What size wire and what kind of conduit... epeterson777 Electrical 15 02-21-2009 08:43 PM
