Conduit Shredding Outer Sheath...tips Please. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2013, 11:34 AM   #1
ericmunyon12345's Avatar
Question
Conduit shredding outer sheath...tips please.
Hey, today I was running individual conductors through 40 feet of emt for receptacles every 10 feet. I ran 4 wires to the end, but pulled one back through the last two boxes as I only needed 3-wire for the last two. Anyway, when I pulled the one wire back I realized that the clear, outer plastic coating got really shredded pulling it in (even with someone helping feed). I was using standard set-screw emt connectors, and was only pulling 4 wires through straight runs of 1/2 inch EMT.
Are you required to use plastic, screw-on bushings like on rigid??? I suppose I could use one on the fitting I'm pulling through until I'm done with the pull. Thoughts?
Any other tips??
Thanks in advance!
ericmunyon12345 is offline   Reply With Quote
Old 06-09-2013, 12:12 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,504
Did you debur the conduit ends? Even fresh uncut conduit has sharp edges....
I use a big a$$ unibit and debur the ends prior to putting them together.
I know it's a pain...but you might want to pull those wires out and make sure they are not nicked down to metal
ddawg16 is online now   Reply With Quote
Old 06-09-2013, 12:41 PM   #3
DIY staff
Rewards Points: 7,174
Yep--You have a burr---can you disassemble the conduit and deburr it?
Always ream the ends of conduit--then stick your finger in and spin the pipe--If you bleed --you need to do it some more.
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
HARRY304E (06-09-2013), jbfan (06-09-2013), Philly Master (06-10-2013)
Old 06-09-2013, 12:43 PM   #4
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
Good one
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
The Following User Says Thank You to HARRY304E For This Useful Post:
oh'mike (06-09-2013)
Old 06-09-2013, 12:49 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,538
Did you mean "stick your finger in and spin the pipe some more"......
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 06-09-2013, 12:59 PM   #6
JOATMON
ddawg16's Avatar
Stick it in and spin? Oh, I am not touching that one.....
The Following User Says Thank You to ddawg16 For This Useful Post:
MTN REMODEL LLC (06-09-2013)
Old 06-09-2013, 01:20 PM   #7
DIY staff
FINGER Ddawg,Finger.
Old 06-09-2013, 01:23 PM   #8
Oso954's Avatar
Rewards Points: 1,030
If you are talking about the clear coating that is covering the black,white, etc, insulation, it is the nylon coating of the THHN. I've seen it come damaged (flaking or chipping) on the reel.
According to Southwire, it is not crucial to the dielectric properties of the insulation. The dielectric properties are in the colored thermoplastic. The nylon coating provides primarily the grease and oil protection. They say that if the installation is not a grease and oil environment, that you can go ahead and use it.
A close examination should reveal whether the nylon is popping off the thermoplastic, or being scraped off.
If the thermoplastic has scrape marks, I would definitely find the burr, remove it, and replace the wire.
Oso954 is offline   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
ericmunyon12345 (06-09-2013), MTN REMODEL LLC (06-09-2013)
Old 06-09-2013, 01:28 PM   #9
JOATMON
ddawg16's Avatar
Oh yea....right.....finger.....
Old 06-09-2013, 05:59 PM   #10
I used a deburring tool. I really think it was from the edge of the threaded part of the emt connector (the end that the wire enters). Sure it couldn't be that? See pic.
Old 06-09-2013, 06:23 PM   #11
Rewards Points: 1,192
Somebody doesn't know how to feed wiire.
bobelectric is offline   Reply With Quote
Old 06-09-2013, 06:35 PM   #12
Buddy was feeding, so not being careful enough might have been an issue. Also, I forgot my pulling lube, but like I said, it was only 40' with nothing but box offsets. The boxes and conduit were ceiling mounted, so I think he was fighting the weight of the spools too.
Your non-constructive criticism helps a lot... that's why I'm asking for tips from the pros who visit this site. I thought maybe a plastic (pvc) screw-on bushing might help where the wire enters.
Old 06-09-2013, 06:51 PM   #13
Mounting the wire spools on a piece of pipe on a ladder would help to keep fighting the loose spools.
The Following 2 Users Say Thank You to bobelectric For This Useful Post:
Old 06-09-2013, 06:57 PM   #14
Just for my knowledge, a potentially stupid question:
It is possible that, with poor wire feeding, the connector damaged the clear coating, right?
Or is it certain that I have a burr? (Which I really don't think I do as I use a conduit scoring tool that claims not to leave them AND an Ideal conduit reamer as well.)
Old 06-09-2013, 08:42 PM   #15
Sparky
Rewards Points: 510
the connectors will chew up the thin plastic if not fed well, yes.
Techy is offline   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
oh'mike (06-10-2013)
Tags
conduit , damage , emt , thhn , tips
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
How to Strip the Sheath HooKooDooKu Electrical 17 01-27-2010 11:25 PM
Sealing conduit coming into house encased with waterline pacamaroman Plumbing 3 06-18-2009 08:48 AM
Running conduit for a pool light KyMike Electrical 12 06-17-2009 03:02 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 05:25 AM
