Conduit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 03:23 PM   #1
Rewards Points: 3,130
Conduit Question
I have many years of electrical experience but have never before worked with conduit. I'm installing a subpanel in a detached garage. The underground conduit is in place and the conductors have been pulled. But how do I connect the PVC conduit to the subpanel and to the main panel? Both have appropriate knockouts but what fitting(s) do I use? Home Depot has threaded x socket adapters but no PVC conduit locknuts.
Old 08-18-2011, 03:38 PM   #2
Master Electrician
Rewards Points: 3,870
Use the appropriately sized metallic locknuts and plastic bushings.
brric is online now   Reply With Quote
Old 08-18-2011, 03:39 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
You won't find pvc locknuts.
You use a TA fitting nad metal locknuts.
If the wire is #4 or larger, you need bushing also.
jbfan is online now   Reply With Quote
Old 08-18-2011, 03:41 PM   #4
Missouri Bound's Avatar
PVC conduit fittings are just like regular pipe fittings, except they are pvc....you glue them instead of using a compression fitting or set screw. And regular locknuts fit the pvc fittings. You will need 4 wires for your sub.
Old 08-18-2011, 04:05 PM   #5
Code05's Avatar
Rewards Points: 1,104
You also need ground rods or other electrodes.
Code05 is offline   Reply With Quote
Old 08-20-2011, 06:45 AM   #6
Thanks for the replies. I was going to use a metal locknut but somehow that didn't seem right so I thought I'd check. And yes, I understand the code requirements of four wires and ground rods.
What conduit should I use? mulltron Electrical 6 07-12-2011 01:34 AM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 05:54 AM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 05:25 AM
Barn wireing and conduit question???? houstonbrama Electrical 8 07-09-2008 01:12 AM
