Conduit: Plastic Or Steel? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 04:46 PM   #1
conduit: plastic or steel?
I'm putting electric in the attic. I am running the wires on the outside of the wall inside the room. According to Pa. law, does it have to be steel or can I use plastic?
akitalover13 is offline   Reply With Quote
Old 06-11-2012, 06:47 AM   #2
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Call the local inspector and ask. You'll get the right answer.
JulieMor is offline   Reply With Quote
Old 06-11-2012, 07:41 AM   #3
Rewards Points: 756
In general, PVC conduit is not a good choice for hot locations. It tends to sag.
Mark
busman is offline   Reply With Quote
The Following User Says Thank You to busman For This Useful Post:
akitalover13 (06-12-2012)
Old 06-11-2012, 08:42 AM   #4
liscenced electrician
Rewards Points: 538
If you run pvc strap it as often as you can in the attic. Something like every 2 feet. Otherwise it will warp really bad due to constant temperature changes. I would run emt if it were me
jimmy21 is offline   Reply With Quote
The Following User Says Thank You to jimmy21 For This Useful Post:
Old 06-11-2012, 09:51 AM   #5
Rewards Points: 812
If you are running conduit on top of joists perpendicular to them its still a good idea to protect the conduit from someone stepping on it. We must use EMT in IL and all the conduit runs in my attic have 2x4s along side the conduit. I presume for mechanical protection. Not sure if it is code or just good practice.
curiousB is offline   Reply With Quote
Tags
conduit
Why do they make copper plated steel pipe hangers? tractorfarmer Plumbing 0 01-15-2012 06:55 PM
What conduit should I use? mulltron Electrical 6 07-12-2011 01:34 AM
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 07:31 AM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
PVC Conduit and steel box Question???? houstonbrama Electrical 4 08-07-2008 11:56 AM
