Old 08-16-2012, 01:14 PM   #1
Busy DIYer
picflight's Avatar
Question
To conduit or not
House has raised foundation with about 24" of crawl space.
I want to do structured wiring for data and phone.
The control panel will be in the garage, phone cable from outside will come here and get distributed.
4 locations in walls where Data/Phone will go, max run from control panel is 20'.
Max fill per location will be 6 CAT5, 1 COAX.
Should I run 3/4" - 1" PVC conduit under the house to each of the four locations or run the bare CAT5 cables?
Opinions, reasoning's welcome.
picflight is offline   Reply With Quote
Old 08-16-2012, 01:22 PM   #2
To conduit or not
If the crawl is not an unpleasant place to be and is critter proof, I would stub pipe from the wall location down so you can properly air seal and then run the lines to the garage in the air.
If the crawl is nasty or critter prone, pipe the whole way.
Evstarr is offline   Reply With Quote
Old 08-16-2012, 03:54 PM   #3
To conduit or not
If your crawl space is anything like mine....the worse thing you will find is spiders...dead ones.....
Exposed is fine....just make sure you nail the stuff up out of the way...otherwise you end up yanking out wires as you crawl around.
BTW....detached or attached garage? If detached....I would run conduit underground between the 2.
jeepdawg is offline   Reply With Quote
Old 08-16-2012, 07:17 PM   #4
Busy DIYer
picflight's Avatar
To conduit or not
How do you keep your spiders dead? I am afraid to get in my crawl space, it is clean and secured but who knows what's in there.
Garage is attached.
Sent from my iPhone using DIY Forum
Old 08-16-2012, 10:54 PM   #5
To conduit or not
They don't live long down there...not much if any food....you see a few spider webs but I have never seen a live spider...that, or the run when they see the light.
I typically use a head light....LED with an elastic band...that way both hands are free to wave the stick to take down the webs.....I HATE spiders...
Anyway....attached garage? Do it like Evstar suggested....
Once you get down there, it's not that bad......one time I fell asleep...took about a 30 min nap.....
Old 08-17-2012, 09:14 PM   #6
To conduit or not
If you run pipe all the way you can leave a string or 2 in the run for later pulls.
But with 6 network cables per box maybe you won't ever need to pull more.
If you don't use pipe use some D-rings or bridal rings.
7echo is offline   Reply With Quote
Old 08-17-2012, 09:28 PM   #7
Master Electrician
To conduit or not
For 6 cat5 and a coax you'll want 1 1/4 inch pipe at least
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Tags
data cabling, structured wiring, voip
Total Degrees of Bend in Underground PVC Conduit tedallen Electrical 12 03-29-2012 09:02 PM
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 06:56 PM
What conduit should I use? mulltron Electrical 6 07-12-2011 02:34 AM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 02:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 07:49 PM
