Conduit Fill Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 10:52 PM   #1
Rewards Points: 252
Conduit fill question
My 17kw generac generator is currently picking up 4 circuits from my main panel, and 8 circuits (all 15 or 20a) from my sub panel. When this was originally installed, there were 8 - 12gauge thhn wires run in 3/4 seal tite from my generator panel to my sub panel. The seal tite ran through the exterior wall where my main panel is located, underground, and then back in the house where my sub panel is, about 30' away. Now that my basement is gutted. I want to run this inside the house. Can I run all 8 - 12gauge thhn wires in a 3/4 flexible metal conduit? I looked up conduit fill, and that seems fine. What concerns me is the derating. Should I run 2 -3/4" conduits and run 4 in each or am I ok with all 8 in one? All 8 wires will be carrying a load. Thank you!!
Thank you!
mazzonetv is offline   Reply With Quote
Old 01-13-2013, 11:21 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 776
Why flexible? I'd do PVC or EMT....and bump it up in size. The cost difference is almost nothing....
I'd go at least 1"....then later on if you want to add something, you have the space.
And....it's a lot easier to fish a fish tape through pvc or EMT than it is flexible...
Old 01-14-2013, 06:06 AM   #3
Rewards Points: 252
PVC is not code where I am. Emt would not work for me. I have to go behind some studs and there are some twists and turns.
Old 01-14-2013, 11:16 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
9 current carrying conductors is the limit for 70% derating. #12 THHN cu will work fine. Only one conduit is needed.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-14-2013, 03:10 PM   #5
Rewards Points: 252
Thank you! After thinking about it, I'm going to run another piece of greenfield anyway. I have it, the walls are open, and who knows if ill need it in the future. =). Much appreciate the replies.
Conduit question. raleighthings Electrical 9 10-06-2011 04:42 PM
Installing central air question about conduit from disconnect to panel angelas111 Electrical 2 05-27-2011 08:37 AM
garage conduit question b_corwin Electrical 19 04-16-2010 01:32 PM
Conduit Fill and Derating jamiedolan Electrical 73 11-19-2008 12:36 AM
Conduit Fill & Ampacity capndave Electrical 37 03-26-2008 03:16 PM
