Conduit/Cable Conundrum - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 02:27 AM   #1
Conduit/Cable conundrum
I'm running 6/3 grounded NM cable across an attic in a single family home and have a question about protection for it:
The cable is running perpendicular to the trusses and is within 6 feet of the scuttle hole, and I was wondering if instead of protecting the cable with guard strips around the hole if it would be acceptable to run the cable though 1 PVC conduit.
I ask because after the cable exits the attic it would be otherwise be exposed wiring; so instead it will be enclosed in conduit & which will then be attached to a 2x4 running board on it's way to the sub-panel. Basically I'm wondering if I can just extend the conduit 6 feet into the attic for protection as well.
shadetree is offline   Reply With Quote
Old 01-16-2012, 02:50 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,990
Yes, you can use a conduit sleeve for protection anywhere that the cable might be subject to damage.
mpoulton is offline   Reply With Quote
Kitchen cabinet conundrum allbymyself Kitchen & Bath Remodeling 18 01-24-2011 11:11 PM
Laminate conundrum Hammerhands Flooring 8 09-11-2010 05:53 PM
Zoning Conundrum MEMama3 Building & Construction 5 04-03-2010 08:17 PM
Please help with my 3 way switch conundrum! campbesh Electrical 9 02-20-2010 01:55 PM
Conundrum: Untwisting a cast iron T amakarevic Plumbing 2 05-23-2007 09:43 PM
