Conduit In To Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 08:47 AM   #1
Rewards Points: 181
Conduit in to Breaker Panel
I'm just checking to see if I've done this right.
From the conduit there is: a locknut, panel wall, locknut, bonding bushing.
Does this look right?
Thanks!
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 09-14-2012, 08:51 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Looks good so far.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-14-2012, 09:12 AM   #3
Code05's Avatar
Rewards Points: 1,104
1. Is this a service/main panel?
2. What size wires are you pulling in that condulet?
Code05 is offline   Reply With Quote
Old 09-14-2012, 10:02 AM   #4
Rewards Points: 181
This is the main breaker panel which is inside (main disconnect is outside in a dual meter base/breaker).
3 @ 2/0 Copper and 1 @ #4 Copper; 2" conduit.
Old 09-14-2012, 10:29 AM   #5
electures's Avatar
If your are installing metal conduit to the meter #4 may not be necessary. Just have to bond the service raceway.
Connecting LB to Breaker Panel tedallen Electrical 5 05-06-2012 11:26 AM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Mounting a generator inlet to the breaker panel erickotz Electrical 2 06-21-2011 12:54 AM
GFCI Panel Conduit Question passmaster16 Electrical 1 06-08-2011 10:28 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
