Conduit Bend Calculation Help - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 05:53 PM   #1
I tried to make a 30 offset bend with 1/2” conduit between floor joists the distance from face of joist to face of joist is 14 5/8”. I used 14 5/8” x 2 for a 29 ” center to center bend. I lined up each mark with the arrow on my Greenlee Bender. I ended up over bending using the 29 centers where did I go wrong?
johnny5 is offline   Reply With Quote
Old 01-20-2009, 06:10 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Are you bending an offset bend? I'm picturing you to be running parallel to a joist and then wanting the conduit to run 30 degrees over to the other joist then continuing parallel to it.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-20-2009, 06:19 PM   #3
Rewards Points: 2,350
Originally Posted by johnny5 View Post
I tried to make a 30 offset bend with 1/2 conduit between floor joists the distance from face of joist to face of joist is 14 5/8. I used 14 5/8 x 2 for a 29 center to center bend. I lined up each mark with the arrow on my Greenlee Bender. I ended up over bending using the 29 centers where did I go wrong?
It's off by the diameter of the pipe. Think about it. Set the pipe on the floor so that the offset is vertical. The 14-5/8"" is from the floor to BOTTOM of the upper part of the offset. But you need 14-5/8" to the TOP of the upper part. SO... the depth of the offset must take that into account, and you must subtract the diameter of the pipe from the measurement.
14-5/8 - diameter = depth
depth x 2 = distance between marks
Also, be sure that you bend both marks with the bender in the same orientation.
Old 01-20-2009, 06:21 PM   #4
Yes, Stubbie am trying to bend a 30 offset from joist to joist. Don't want to trash another piece of conduit would appreicate any expertise.
Old 01-20-2009, 06:40 PM   #5
Thanks InPhase277, I did think about subtracting the 1/2" pipe daimeter roughly 3/4" to make my bend but needed to here it from someome with a bit more experiance would rather not trash another length.
Thanks again
Old 01-20-2009, 06:49 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Inphase nailed it.... your distance between bends is 2 x 13 7/8 or 27 3/4". 13 7/8" is your offset height. Shrinkage is 3 3/8".
Stubbie
Old 01-20-2009, 08:29 PM   #7
Licensed electrician
Rewards Points: 1,634
You could still use the piece that is too long if you just allow it to roll uphill slightly. This will eat up the extra depth of the offset.
Old 01-20-2009, 09:34 PM   #8
Electrician
Rewards Points: 794
Are you wanting to make more then one of these bends and make them all match? If your not why don't you just put a little more bend in or a little less to make it fit, it won't be a perfect 30 degree bend but no one will notice if there is only one.
darren is online now   Reply With Quote
Old 01-20-2009, 09:41 PM   #9
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I'm with Darren on this one. Unless you are trying to match an existing pipe, I would simply take a little of the bend out. It won;t be much since you are talking 3/4 of an inch less offset..
With 1/2" you can simply place the pipe on the floor with the offset standing up and pushing gently on the angled part to straighten it just a wee bit. Do that to both bends equally. Then take the bender handle and lay the short part of the pipe against the handle and compare the other end of the pipe to the handle to make sure it is parallel to the shorter part.
Old 01-20-2009, 10:35 PM   #10
Smile
Nope just going to bend the one pipe will try your method of salvaging before I try to bend another.
Thanks for all the input.
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
#3 AWG Copper SER / PVC Conduit Question djejay75 Electrical 4 12-11-2008 11:40 PM
Conduit for #6 wire joey b Electrical 13 11-22-2008 12:13 PM
Conduit Fill & Ampacity capndave Electrical 37 03-26-2008 02:16 PM
