Conduit Behind Wood Trim? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 07:15 PM   #1
conduit behind wood trim?
I'd like to install a ceiling light in my kitchen and there is a convenient 1/2" x 1" gap that's covered by wood trim. So, I'm wondering if it is acceptable to run wire inside a conduit thru that gap as a way to wire a new light.
Btw, this isn't crown molding, just a couple of generic 3/4" wood trim pieces that meet at a right angle where the kitchen ceiling (standard drywall) meets up with a vaulted, exposed beam ceiling. The drywall doesn't go all the way to the edge of the trim (horizontal and vertical) which is the source of the gap.
Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 01-08-2012, 07:43 PM   #2
Rewards Points: 13,750
Is this a one story building?
Far better to run it through the attic when ever possible. There's a good chance of hitting the wire with a nail.
Old 01-08-2012, 07:54 PM   #3
It would be possible to go thru the ceiling, but a whole lot more work. So, at this point I'm just trying to get answers to the following:
1) Would it meet code requirements to run the wires in a conduit as stated
2) Assuming it is allowed, is it a good idea
Thanks for weighing in on point 2).
Old 01-08-2012, 08:02 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Got a picture of what youre trying to do?
plummen is offline   Reply With Quote
Old 01-09-2012, 01:28 AM   #5
Julius793's Avatar
If it's in conduit I wouldn't think twice, the question is more without conduit and how to understand the nec when it says physical damage or similar terms.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-10-2012, 12:29 AM   #6
Thanks. That was my thinking.
Regardless, I went ahead and opened up the drywall (ceiling and wall) and put the romex thru the attic space. It was even more work than I expected---lots of weird angles, beams, etc. Anyways, it's almost all done, and should be finished tomorrow.
Old 05-28-2013, 04:45 PM   #7
Wiring and Crown Modlings
I am wondering if I might cut the top of the molding off and replace it with a metal square conduit that can be painted to match and look like the top part of the crown molding. It might not match the other crown modling exactly, but it would not be obvious unless one looked closely I think.. I would remove a strip of drywall at the top so the conduit would be mounted as required on the studs...
I have seen metal crown molding conduits that I wish I had used before placing the molding I have now.. Running wires would be very easy If I had...
Mike from Virginia
MichaelVirginia is offline   Reply With Quote
UN-painting wood trim in a California Craftsman!? TOTALN00B Remodeling 6 02-21-2011 06:07 AM
Help selecting wood to trim out interior windows and doorways RobertN Carpentry 11 01-07-2011 04:38 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
Should I seal where wood trim meets the brick? megan81 Building & Construction 1 07-01-2008 12:40 PM
Tile with a wood trim? trick29392 Flooring 3 06-26-2008 07:19 AM
