Conduit - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-30-2010, 06:46 PM   #16
Mad Scientist
If I had to improvise a tool for making various bends in EMT, I'd probably come up with something like an L-shaped piece of bar stock with a couple of 1/2" metal pins sticking out from the sides at the corner and bottom tip of the L. Like this:
The dashes are the bar stock, and the pins are the asterisks. By positioning the tool with one pin over and one pin under the EMT, you can bend it a little, slide the tool along, bend it a little, and so on.
Or just go buy a hickey. It's pretty much the same principle, but designed for the purpose.
McSteve is offline   Reply With Quote
Old 08-30-2010, 09:27 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by RDGreen View Post
That is one impressive looking tool...
However it's probably got an impressive looking price on it too...
This will be most likely a one time deal so is there any ideas on making a tool from scrap steel or wood that will do the job for me???
Not really it only cost me couple hundreds Euros and I used more than just electrical conduit but used on other items as well.{ I have this one for over 15 years }
You can make a jig rig of plywood and use the roller to follow the curve of the plywood { you will have to make couple layers to handle the pressure of the conduit }
Merci.
Marc
Old 08-31-2010, 10:36 AM   #18
Rewards Points: 126
This is what most people use to bend EMT conduit.
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 12:09 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
