Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2010, 09:55 AM   #1
Conduit
I'm going to use conduit to make a large fan cage and I need to know the difference between rigid and emt conduit...
I want the lightest weight ...
Have to make a 4' diameter ...
and weld it all together ... (what material are they made of?)
RDGreen is offline   Reply With Quote
Old 08-27-2010, 10:20 AM   #2
Licensed electrician
Rewards Points: 1,892
Rigid conduit is a thick pipe and is normally threaded.
EMT is a thin walled tubing. If you were to try and weld it you may burn through, but it might be worth a shot.
Old 08-27-2010, 10:39 AM   #3
Is emt steel or allum?
Old 08-27-2010, 11:32 AM   #4
EMT is typically steel.
Old 08-27-2010, 11:34 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Both will be galvanized, so take welding it.
Emt is lighter than ridigd, but use 4" it will be heavey anyway.
jbfan is online now   Reply With Quote
Old 08-27-2010, 10:05 PM   #6
Union Electrician
goose134's Avatar
I don't think I've ever seen anyone try to weld EMT or rigid for that matter. EMT will keep the weight down for sure. FYI there are manufacturers who make EMT in aluminum AND stainless.
You'd puke at the price, but it's out there.
goose134 is offline   Reply With Quote
Old 08-28-2010, 09:32 AM   #7
Rewards Points: 246
EMT can be braised with good success. I have a friend who makes deer stands and racks for ATV's out of EMT. I bent the pipe for him on the first couple projects and he has been doing it all by himself since. EMT is perfect for braising.
Old 08-28-2010, 09:43 AM   #8
Originally Posted by J. V. View Post
EMT can be braised with good success.. EMT is perfect for braising.
You might be able to braze EMT sucessfully, but I doubt that it will ever end up tender if you braise it.
braise (brz)
tr.v. braised, brais·ing, brais·es To cook (meat or vegetables) by browning in fat, then simmering in a small quantity of liquid in a covered container.
Sorry John, just couldn't resist.
Old 08-29-2010, 08:05 AM   #9
I=E/R
a7ecorsair's Avatar
braise (brz)
This should help....................
an·neal
a : to heat and then cool (as steel or glass) usually for softening and making less brittle
a7ecorsair is offline   Reply With Quote
Old 08-29-2010, 11:20 AM   #10
Rewards Points: 246
braise (brz)
That's okay Jim. I had it coming.
Old 08-29-2010, 11:49 AM   #11
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if you are a decent welder and have a decent and appropriate welder, EMT can be welded successfully as well.
Old 08-29-2010, 04:04 PM   #12
Question
I want to thank you all for the great information on EMT and how to weld and or cook it...( lol )
My next question on this EMT matter is,,, How would I bend it into a nice looking 4 foot diameter? (No Corners or Abrupt Bends) ???
Old 08-29-2010, 07:27 PM   #13
For a sweeping bend like you need you would use a hickey and make segmental bends. You would need to do some math to get both the angle and spacing worked out.
Old 08-30-2010, 01:47 AM   #14
" Euro " electrician
frenchelectrican's Avatar
For very large radius bending this what I used from time to time.
That useally do the trick with very large radius.
Merci.
Marc
Old 08-30-2010, 04:38 PM   #15
That is one impressive looking tool...
However it's probably got an impressive looking price on it too...
This will be most likely a one time deal so is there any ideas on making a tool from scrap steel or wood that will do the job for me???
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
How to plug unwanted and leaking conduit? gernith General DIY Discussions 6 08-08-2010 12:09 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
