Conduit - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2008, 04:23 PM   #1
Master Of Nothing
mr500's Avatar
Conduit
Im about to run my feeder into my new workshop and was wondering when I drill down through the bottom plate and bring in my feeder, whats the codes say about this part of the wire having to be in conduit?. I mean the part from the floor up to the bottom of my panel?
Also, is it within code to use plain 12 awg (green) for pigtails on the grounds?? I cant find plain copper in 12awg. Prolly a stupid question there, but I just wanted to know. LOL
mr500 is offline   Reply With Quote
Old 03-19-2008, 05:24 PM   #2
Rewards Points: 150
What type of wire are you using.
JGarth is offline   Reply With Quote
Old 03-19-2008, 05:27 PM   #3
Master Of Nothing
mr500's Avatar
Al 2-2-4-6
Old 03-19-2008, 07:09 PM   #4
electrical contractor
Rewards Points: 150
If the wire is type USE it must be in pipe all the way to the panel, if it is SE-U or the like does not hhave to be in pipe, but would be in my shop. The green wire is fine for ground pigtails as long as the other grounds are 12awg or smaller, and copper, do not join copper to aluminum!
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 03-19-2008, 07:12 PM   #5
Master Of Nothing
mr500's Avatar
Im not sure on the type. i do know that it is direct burial mobile home feeder. Ok so i can use the green..Good deal. Ill buy some off a roll for my grounds in the box's.
Mike
Old 03-20-2008, 06:40 AM   #6
Rewards Points: 150
Direct burial wire usually type USE has to be buried or in pipe from panel to panel not allowed to be exposed.
Jimmy
Old 03-20-2008, 08:13 AM   #7
ground pigtails
You can buy the pigtails already made up with the ground screw attacked. An electrical supply house would have them, and they will sell you any number of them. If you buy a whole box it ain't cheap.
RobertS is offline   Reply With Quote
Old 03-20-2008, 01:32 PM   #8
Res Ipsa Loquitur
Regarding the pigtail grounds: There are 3 types I have seen in home stores usually by Ideal-
A wirenut on one end and a green screw on the other, a screw on one end and a spade tip on the other; a screw at one end and just a bare end on the other.
The first 2 are stranded 12g, the last is solid 12 or 14 I think?
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 03-20-2008, 04:11 PM   #9
Master Of Nothing
mr500's Avatar
Ok Thanks,,,
Robert..I dont need to gnd screw, Ill be using these to pigtail the gnd coming out of my plugs n so forth. I have seen the pigtails that HD and such carry. Ill look at them closer this weekend. I think i still have some UF 12-2 about 15 ft i might just use the bare out of that. I dont need it for anything else its too short..
Good stuff thanks
Mike
Im Not An Electrician...But I Did Stay At A Holiday Inn Express Last Night!!
Old 03-20-2008, 04:23 PM   #10
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I use these. Quick and easy.
http://www.idealindustries.com/produ...ut_greenie.jsp
jrclen is offline   Reply With Quote
Old 03-20-2008, 04:28 PM   #11
Master Of Nothing
mr500's Avatar
Yes seems so. I have seen these in the wiring books. Have to check out my supply stores and see if I can get them.
Mike
Old 03-21-2008, 09:01 AM   #12
jrclen's Avatar
Rewards Points: 514
Most big box stores carry the greenies. As you can see in the picture, the wire which passes through the hole becomes the pigtail and any other grounds are connected inside the wire nut as normal.
Pvc Conduit bobo60 Electrical 1 11-14-2007 09:52 PM
Conduit issues - help needed nymackem Electrical 19 11-05-2007 06:45 AM
Conduit through basement wall. bdalekid Electrical 13 01-31-2007 08:35 PM
Running Conduit in new basement framed walls tben Electrical 3 12-10-2004 11:14 PM
