Conductor Sizing - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-04-2013, 10:31 PM   #31
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Also after your first disconnect you have to run a four wire feed to the rest of the structures.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-04-2013, 10:42 PM   #32
Rewards Points: 506
And we're back to the original issue. The POCO installed the feeders which are utilized after the first disconnect.
jlmran is offline   Reply With Quote
Old 03-04-2013, 11:07 PM   #33
Rewards Points: 1,542
No inspection occurred because I assume the inspector simply wants the permit money. Its in a rural location but it is incorporated into the town limits. Maybe he is lazy? I don't know...he is more than welcome to come inspect...he just doesn't do it. Write a check...get a permit filed...do the work. Small town culture.
The inspector has to sign off on the permit when you have completed the job including any rework for deficiencies the inspector might have pointed out, after which time the insurance company cannot deny a claim because work was not done to code.
Old 03-04-2013, 11:23 PM   #34
Rewards Points: 506
He is the AHJ. You think I'm going to tell him what he has to do and when he has to do it?
Old 03-05-2013, 05:25 AM   #35
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I doubt he is the AHJ, most if not all inspectors, are NOT the AHJ.
Old 03-05-2013, 05:26 AM   #36
E2 Electrician
I missed this fact, I was under the impression you ran the feeder after the disconnect, and the utility only ran the conductors supplying the meter...
Old 03-05-2013, 05:32 AM   #37
Rewards Points: 506
So who would be the AHJ in this situation?
Old 03-05-2013, 10:17 AM   #38
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Please explain.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 03-05-2013, 10:41 AM   #39
You mean he customarily signs off on it before you are done? Since you inquired on this forum you learned what the correct materials and methods are.
Old 03-05-2013, 11:50 AM   #40
Rewards Points: 506
I don't know if an inspector exists. I do know a permitter exists. Permits are required to be purchased. Once the permit is purchased and issued, you can do the work.
Some might call it a tax.
Old 03-05-2013, 04:18 PM   #41
E2 Electrician
Originally Posted by electures View Post
Please explain.
Its very simple, most inspectors are not the AHJ, in the state of Connecticut, every town has a hired official to inspect electrical work, they are NOT the AHJ, they must either pass or fail the job being to code per the NEC... they may think they have power over the NEC, but its just a god complex.... the AHJ in connecticut is actually the State electrical inspector, but even that could probably be fought since its just a job title....
Old 03-05-2013, 04:52 PM   #42
Rewards Points: 506
It is my understanding that the NEC has zero authority, unless it is adopted by some legally governing body. The individual representing the governing body, as well as the governing body, would be the AHJ.
If the governing body elects to NOT use the NEC as a basis for electrical installation compliance, then the NEC is meaningless in that area governed by that body.
Old 03-05-2013, 04:56 PM   #43
E2 Electrician
It's a very confusing topic, thats why I say the inspector is probably not the AHJ...
Old 03-05-2013, 06:03 PM   #44
Rewards Points: 506
I'm not confused. If I perform work without securing a permit from the code enforcement division identified by the town council then I have violated a town ordinance, which could subject me to legal actions, fines, discipline, et cetera. The town council has identified an individual as an issuer of permits. Perhaps the permit dude is an inspector also. Either way, the permit dude represents the authority which has jurisdiction over my actions. If the town council is required to adopt codes or standards because of county or state level regulations then that is the council's business.
All I know is that the code enforcement division of the town government requires a permit from this dude, so therefore he is, or represents the AHJ.
I suppose its like line side versus load side...it's all relative to your location.
Old 03-05-2013, 06:46 PM   #45
E2 Electrician
The permit dude or the inspector dude does not make him/her the AHJ... just saying... its just their job to inspect electrical installations...
