Concrete Pad - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 05:33 AM   #1
Concrete pad
Someone tell me how far off of the side of the pad I should place my conduit before I have the concrete truck come.
Joe1959 is offline   Reply With Quote
Old 12-12-2012, 05:57 AM   #2
Rewards Points: 2,516
If you are referring to the perimeter of the patio, like whats shown in red in the photo...why would you lay it before the concrete pad is poured. Has a chance to get stepped on while concrete is being poured/finished. Or does some part of the conduit have to go under the pad? I didnt find anything in the code about proximity to the permeter of the concrete when I did mine.
hammerlane is offline   Reply With Quote
Old 12-12-2012, 11:33 AM   #3
Rewards Points: 174
I would go under the pad if it saved distance and material.
Old 12-12-2012, 12:05 PM   #4
I would go around the pad if possible.
Old 12-12-2012, 03:34 PM   #5
Rewards Points: 1,192
Conduit for what?
bobelectric is offline   Reply With Quote
Old 12-12-2012, 05:58 PM   #6
Hammerlane I am going to put a metal garage on the pad and I was going to put a 90 degree PVC conduit near the edge of the pad inside so I can run power from my house later.I know I could go up the side of the garage later but I would prefer having a way of getting the power inside without drilling a hole on the side of the garage. Thanks
bennie59 is offline   Reply With Quote
Old 12-12-2012, 06:08 PM   #7
did the original poster of Joe1959 turn into Bennie59. Sounds like Bennie59 was answering Joe1959s situation
Old 12-12-2012, 06:08 PM   #8
Originally Posted by bobelectric View Post
Conduit for what?
Bobelectric I was putting a metal garage on the pad and I want to run power From my house to the garage.I was going to place a piece of 90 degree PVC conduit near the edge of the pad inside so I could feed my power in the garage thru the 90 degree elbow but I don't know how far over from the edge I should place it before I pour the floor. Thanks
Old 12-12-2012, 06:11 PM   #9
you referring to the inside edge of the pad or the outside edge
Old 12-12-2012, 06:16 PM   #10
Smile
Hammerlane hahaha yeah I am the same person I'm not much on computers don't know how I got to names going on sorry about that.
Old 12-12-2012, 06:20 PM   #11
The inside edge,I want to put it in place before I pour the floor so I can get power inside the garage later.
Old 12-12-2012, 07:10 PM   #12
Licensed electrician
Rewards Points: 1,634
What is the wall thickness and the wall material?
Old 12-12-2012, 07:21 PM   #13
Jim it's one of them metal carports enclosed with an overhead door.I'm not sure about the thickness but I can call the manufacturer and find out.
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 05:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
