Concrete Footing 2" Underground, What To Do? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 01:40 PM   #1
Concrete Footing 2" underground, what to do?
Hello all. I am running electricity to an out building thta is approx 70 years old and have hit a glitch. The concrete footing which is 2" underground comes out from the building about a foot and is prob 8" thick. The attached photo isn't great but, might help. Would it be legal to bring the sched 40 PVC out of the ground at the edge of the concrete and then run across the top to the building at ground level for that last foot. Any other suggestions would be greatly appreciated.
boat73 is offline   Reply With Quote
Old 11-20-2011, 01:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The concrete footing is...
two inches underground, or,
two feet underground?
Old 11-20-2011, 02:20 PM   #3
Rewards Points: 6,652
Photo, what photo. Oh, the mystery thickens.
Old 11-20-2011, 02:42 PM   #4
1. thanks for the quick replies
2. it is 2 inches underground, extends a foot from the building and, is about 8 inches thick.
3. hmmm, the picture was there honest. i have attached it this time.
Old 11-20-2011, 02:56 PM   #5
Milwaukeetool's Avatar
I believe it is a 2" slab that the out building is built on rather than a footing.
Milwaukeetool is offline   Reply With Quote
Old 11-20-2011, 02:57 PM   #6
I=E/R
a7ecorsair's Avatar
I don't see in the picture where the footing extends beyond the wall a foot. It looks flush to me
a7ecorsair is offline   Reply With Quote
Old 11-20-2011, 03:13 PM   #7
boat73, you are going to have to pull the dirt off around the structure to see how far the material runs along the length. It could just be block, but you will not know, until you do more excavating.
Old 11-20-2011, 03:31 PM   #8
Rewards Points: 150
Why not line up the trench with a corresponding point on the inside of the shed and drill a 2'' hole right through the concrete. It is most likely less than 8'' thick anyway on the inside of the wall. Then extend the trench and dig under the projecting concrete edge beam. If you push a broom handle or similar piece of wood, you will see where the bottom of the hole you drilled is. Then run the 40mm conduit in the trench and up through concrete floor on the inside of the wall. Continue the conduit vertically to serve a power point or sub switchboard. Note the actual wiring and connections must be carried out by a qualified and licensed electrician. That way, the conduit is fully protected, out of site and neatly fixed to the wall on the inside. There are codes about the depth of trench for electric conduit, the protection of the conduit with concrete pavers and marking of the conduit route with special conductive tape, so you may need to just dig the trench and leave the rest to the electrician.
Cheers from the big Oz.
JoJo-Arch is offline   Reply With Quote
Old 11-20-2011, 03:40 PM   #9
Rewards Points: 150
I would also add that drilling a 2'' hole with today's drills is straight forward. I purchased a hammer-rotary drill for $50 plus a set of diamond tipped core bits 1'',2'',3'' and 4'' for $40 from our supermarket chain Aldis and these bits will drill to 10''. I know it's an el cheapo, but so far its been fine for drilling a small number of large holes in concrete. That's all I expected it to do.
Cheers, from Oz
Old 11-20-2011, 03:58 PM   #10
Thanks all, i know that picture is hard to see all the depth. I marked this one to try and make it easier to see all the dimensions. I have drilled concrete before but was hoping there would be a better code approved method. The concrete has a lot of rocks in it so I wasn't sure if that might make it harder to drill. I suppose I could just use a hammer drill to chissel ot a channel if i had to.
Old 11-20-2011, 04:36 PM   #11
liscenced electrician
Rewards Points: 538
why not just come up on the outside and LB into the shed?
jimmy21 is offline   Reply With Quote
Old 11-20-2011, 05:05 PM   #12
Rewards Points: 150
Yep! as I said, the code will not let you have exposed conduit externally unless is properly protected. Rember when the weeds grow and you forget about the conduit down the track, the first time you dig the weeds according to Murhy's law, will be when you don't need drugs to see the light.
Cheers from an architect that is trying to save your life. .
Old 11-20-2011, 05:06 PM   #13
I am using an LB but, does the LB need to be right at the wall or can it be 6 inches out with a section of PVC between it and the house?
Old 11-20-2011, 10:31 PM   #14
Rewards Points: 538
Don't do that, just heat the pvc and it will bend like a wet noodle. Not hard at all. Also, bring the LB up above weed height, so you don't forget its there. I don't know about other areas, but around here, the AHJ does not consider this application exposed to physical damage.
Old 11-21-2011, 07:08 AM   #15
Licensed electrician
Rewards Points: 1,506
I would consider that area subject to damage from lawn mowers and string trimmers.
A sweeping offset could be used to get over the footing.
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 08:46 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 05:03 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 06:52 AM
What is the on the base of the footing for standard circular steel form work for concrete be 12" wall and 36' foundation undation? william lum Building & Construction 1 06-24-2010 06:45 PM
