Concerned About Hooking Up Main Power - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-21-2012, 02:32 PM   #31
Rewards Points: 1,294
Power companies in my are will not power up a service (install meter) unless the main breaker is off. After they power up the service, turn all branch circuits off, turn the main on then turn on the branch circuits. If you are sure the work was done properly then there should be no issues.
danpik is offline   Reply With Quote
Old 09-21-2012, 02:45 PM   #32
thank you danpik. Amazing, it took two full pages to get the simple answer i was after. I knew they wouldnt hook it up with the main breaker turned on, i just wasnt sure how to go about turning it on afterwards. thanks.
firsttimeremode is offline   Reply With Quote
Old 09-21-2012, 04:09 PM   #33
just making the best of a bad situation. If it makes me an idiot to check on a method before i just go in there all gung ho and get myself killed, then sorry but im going to check. No sense in calling people names.
Old 09-21-2012, 07:13 PM   #34
DIY staff
Rewards Points: 7,174
I'd shut this down, but the OP is trying to learn something---I think----
Let the moderators know if it's time to pull the plug on this one----
To the OP---you have the assistance of some very skilled and experienced pros---watch the wise cracks---they are being generous to you---a thank you would go a long way.---Mike the Moderator----
JetSwet (09-22-2012)
Old 09-21-2012, 11:29 PM   #35
Registered User
Rewards Points: 5,244
To all whose posts are now gone;
Forum Posting Rules:
The following is a list of basic guidelines about what is and is not allowed while posting on DIYChatroom.com. These rules are in addition to what is listed in our Terms Of Service , and Advertising Rules. Please read through all of these sections before using our site and contact us if you have questions..
  • Users shall treat each other with respect at all times on DIYChatroom.com. Name calling, personal attacks, or other inappropriate behavior will not be allowed and may cause your account to be banned."
Gary
Old 09-21-2012, 11:46 PM   #36
you can close the thread if you want, ive got my answer. sorry bout the sarcasm ya'll. Everyone have a nice evening.
Old 09-22-2012, 01:22 AM   #37
Registered User
Not necessary. As long as information is being exchanged to help others reading this in the future with a similar problem...that is our main goal here.
Thank you for your understanding.
Gary
Old 09-22-2012, 02:45 AM   #38
" Euro " electrician
frenchelectrican's Avatar
Let me add something else along the way here .,
If you do have the generatour running now and when the POCO do make the hook up the POCO will have a very strict policy that when they see that running they will NOT engerized the power source until the generatour is off then they can able engerized the source.
The reason is for your own safety and POCO safety so no one will get hurt from this.
I have see couple generatours blew up when the POCO engerized the source it is not a pretty sight at all.
Merci,
Marc
Old 09-22-2012, 09:21 AM   #39
Note: After power is connected, be sure to check every single outlet with a voltmeter to be sure it has the correct voltage and it is wired correctly (before plugging anything in). Check all switches to be sure they work ok.
Very rarely you might get a switch or outlet which has a manufacturing defect and does not work.
And mistakes happen. The wires going to a 240 volt outlet can look the same as the wires going to a 120 volt outlet. So easy for someone to install the wrong outlet or mix up wires at the panel.
I always do that even if I was the only person doing the work. Good to double check and test!
Billy_Bob is offline   Reply With Quote
Old 09-22-2012, 09:40 AM   #40
i'm thinking if it didnt spark when you had your gen set on it, it won't when they hookup ur mains man, so don't worry
DShdw is offline   Reply With Quote
Old 09-22-2012, 01:37 PM   #41
Oso954's Avatar
Rewards Points: 772
Bad Advice!
Oso954 is offline   Reply With Quote
The Following 2 Users Say Thank You to Oso954 For This Useful Post:
frenchelectrican (09-22-2012), Speedy Petey (09-22-2012)
Old 09-22-2012, 05:32 PM   #42
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Wow. Please think twice before posting advice to the electrical board.
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 03:09 PM
Changing a breaker. Turn main power off first? noone Electrical 18 11-15-2011 08:08 PM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 10:53 AM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 04:19 PM
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
