Conceal Wiring From Security System - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 08:17 PM   #1
Conceal Wiring from Security System
My home had a security system from a previous owner. I've removed the motion sensors from various points on walls, leaving the in-wall wiring exposed.
What's the best way to conceal the wires that fed the motion sensors?
I was thinking of electrical tape + wire nuts on the wire ends, but was wondering if something like a plastic screw cap was made for wiring--leaving only the screw cap visible, flush with the wall. I'd like to leave the wires accessible to a future owner that may want to wire a security system, but I'd like the connections to be masked as well as nicely possible.
Thoughts? Thanks.
jett is offline   Reply With Quote
Old 08-01-2011, 08:29 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
I would not worry about leaving the wires for a future system, most new security systems are wireless.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 08-01-2011, 08:37 PM   #3
Missouri Bound's Avatar
Well if you want to leave the wire in place, there are low voltage "boxes" which are open back. The wire could be pushed back into the wall and secured to these boxes, then a blank plate wold cover the box.
Old 08-01-2011, 08:42 PM   #4
Rewards Points: 6,652
Push back into the wall, then use a little white paint-able caulk to close up the small hole where the wire came through. Do not have to do anything to them, other than make sure disconnected on other end from the box. If this system was installed well after the structure was built, you should be able to just pull them completely out of the wall.
Old 08-02-2011, 10:07 PM   #5
All - Thanks for the replies. I know nothing about electrical systems, so thanks for the input. I do not trust myself to wire a box or make the hole in the wall needed to do so; I did not know that most security systems were wireless these days (makes sense though, tis the age); and I believe I can manage to caulk a less-than-a-quarter-sized hole. Thanks!
Old 08-02-2011, 10:10 PM   #6
If the hole is larger than your pinky tip, use Spackle to close up. Anything larger that needs a piece of drywall tape, will need to be repaired with compound & fiberglass tape.
DIY Home Security System (suggestions needed) tigerbalm2424 General DIY Discussions 10 06-13-2011 03:54 PM
Electric Run, Voltage Drop Issues. Eventual upgrade of system this year. lawnphysics Electrical 4 04-06-2011 07:24 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
