Computing Amperage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2008, 10:34 PM   #1
Computing amperage
The manual for my ceiling fan says that on medium it uses 32 watts and .51 amps. But this does not make sense to me because 32watts/110 Volts = .29 amps or 32watts/120 volts = .27 amps. Am I missing something?
It does have a light kit which uses two 60 watt bulbs which should be drawing 1.09 amps whenever the light is on, but I don't think that has to do with the computation for the fan itself.
farmerde is offline   Reply With Quote
Old 11-16-2008, 10:47 PM   #2
DIYer
This could be explained by the power factor of the motor not being exactly balanced. The motor is inductive.
http://en.wikipedia.org/wiki/Power_factor
The light is not counted in that nameplate rating on the motor.
Gigs is offline   Reply With Quote
Old 11-16-2008, 10:55 PM   #3
WFO
Your math would be correct if the fan was a purely resistive device. However, it is inductive so you would have to include the cosine of the angle between the voltage and the current.
By the numbers posted, it appears the cosine would have to be about .51 or roughly 60 degrees (which might be about right in a fan with little load on it).
WFO is offline   Reply With Quote
What was the code requirements on amperage? rgsgww Electrical 3 09-05-2008 12:33 PM
Can I double wire and increase amperage capacity? YerDugliness Electrical 24 08-22-2008 06:45 PM
How to determine DC amperage required for small device? quexal Electrical 3 05-11-2008 02:04 PM
How can I determine service amperage? dawho1 Electrical 13 04-07-2008 11:10 AM
How do panels get their amperage rating? Randell Tarin Electrical 14 01-23-2008 07:10 PM
