Compressor Voltage Change - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2013, 06:52 PM   #1
Rewards Points: 18
I have a 15 year old DeVilbiss (now Porter Cable?) Model F412-2 air compressor. It is rated as 120/240V but I do not have a wiring diagram. It is presently factory wired for 120V but I need to convert it to 240V. A $35 voltage conversion kit (Part K-0084) is available but it appears from the parts diagram that it is just a new cord with the proper plug.
The contactor (pressure switch) has only 2 line terminals and two load terminals. Is it possible that the voltage change is as simple as changing the plug and the motor (pump) will run on 240V with no other changes?
Thanks for any help you can give me.
IdahoBob is offline   Reply With Quote
Old 12-08-2013, 07:29 AM   #2
Rewards Points: 14,312
Have you pulled the cover off where the wires connect to see if the diagram is on the back side of the cover?
oh'mike (12-08-2013)
Old 12-08-2013, 07:49 AM   #3
DIY staff
Rewards Points: 7,174
I moved this to 'electrical' for you---the electricians should be able to walk you through this----and ,as Joe suggested, the wiring diagram is often on the motor under the cover plate.
Old 12-08-2013, 08:17 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would recommend you buy the kit. You will need a new cord end anyway.
Old 12-08-2013, 08:19 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
It is not the pressure switch that needs rewiring, it is the internal motor wiring.
Save the $$ for the conversion kit. Cut the plug off the cord and intall the correct plug. Or hard wire it.
Coastal South Carolina
Old 12-08-2013, 08:23 AM   #6
k_buz's Avatar
$35 is cheap for the listed parts conversion...it will probably come with instructions as well.
Old 12-08-2013, 08:30 AM   #7
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
As long as the box was never opened
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 12-08-2013, 01:39 PM   #8
Idiot Emeritus
Rewards Points: 1,492
Changing the voltage from 120 to 240 is easier than the other way around. All wiring is of sufficient size.
Assuming that the control scheme is power to the pressure switch, then directly to the motor (no starter), all that's needed is to change the plug on the end of the cord (or hardwire it to a disconnect switch), and re-connect the motor for the higher voltage.
If there isn't a wiring diagram on the motor, post the motor wire colors/numbers and we'll come up with the 240 volt connection.
Rob
micromind is offline   Reply With Quote
Old 12-08-2013, 02:16 PM   #9
Rewards Points: 18
Problem Solved. Thanks for all the help.
After I got the shroud off (2 piece but glued together ) and exposed the motor, there was the wiring diagram just as you predicted. A simple change to the wires and a new plug on the end of the cord and I will be good to go.
Again, thanks for all your help and to Joe for moving the thread to Electrical.
Won't Start, Won't Change Gears fatcatsam2 Automotive Repairs 9 01-04-2011 04:37 PM
Can't afford to change out Zinsco panel - best next step? dwoloz Electrical 12 08-20-2010 12:28 PM
is UG conduit size change legal? krazni Electrical 1 07-13-2010 02:17 PM
How hard is it to change locks/tumblers? abefroman Remodeling 4 03-04-2009 08:33 AM
change color of flooring and other wood finishing, possible? KUIPORNG Remodeling 3 07-20-2006 06:54 PM
