Compressor Magnetic Starter (Need Help) - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 09:17 PM   #1
Hello everyone, I have an Ingersoll Rand 60 GAL compressor. A friend gave it to me, but the only issue is that someone ripped out the original magnetic starter, i ran across a used box, but i cant figure out what goes where, I can hook up everything but the motor. There is four wires, a green one, which I know it is the ground wire, and three black wire, I can only assume they are HOT wires, and that is where im stuck. Not sure exactly where they hook up to. Can anyone give me tips, advise or tell me where they go?
Thank you,
Jesse
Compressor Magnetic Starter (Need Help)-compressor3.jpg   Compressor Magnetic Starter (Need Help)-compressor1.jpg   Compressor Magnetic Starter (Need Help)-compressor.jpg
Jesse69 is offline   Reply With Quote
Old 07-07-2012, 09:25 PM   #2
Rewards Points: 3,256
I'm going to guess that you have a 3 phase motor on your compressor. Are you planning on using this at home (single phase) or in a commercial building that has 3 phase power?
zappa is offline   Reply With Quote
Old 07-07-2012, 09:31 PM   #3
i am using it in my home,
Old 07-07-2012, 09:39 PM   #4
Can you verify from the motor tag if you have a 3 phase motor? If so, you will need to install a single phase motor or buy a phase converter. Could be quite a sum of money either way.
Old 07-07-2012, 09:44 PM   #5
what am i looking for on the motor to verify its a 3 phase?
Old 07-07-2012, 09:46 PM   #6
biggles's Avatar
the starter is single phase overloaded for 230V,can't be used on that motor and it is 3 phase that is a commercial air compressor.motor change is required and if you go for a motor new with a new contactor and fused disconnect..check out www.grainger.com for all the items rpms/hp and frame critical for a new setup...throw in a new pully on the motor also... maybe belt....
Old 07-07-2012, 09:51 PM   #7
well it does say PH3 on the tag, so i guess it is a phase 3 motor
Old 07-07-2012, 10:05 PM   #8
Ingersoll Rand Compressor going on Craigslist...
thank you everyone for your assistance.
Old 07-07-2012, 10:09 PM   #9
You are welcome. Would you happen to be close to D.C. or Baltimore?
Old 07-07-2012, 10:11 PM   #10
no... Houston, TX
Old 07-07-2012, 10:21 PM   #11
You have a nice compressor if it's in good shape. The problem is high horsepower single phase motors are pricey unless you are lucky and can find a used one that will fit.
Good Luck
Old 07-08-2012, 10:16 AM   #12
Rewards Points: 240
You can use a simple VFD for converting single phase to three phase for less money than the single phase motor. If you have no clue regarding electrical operations, go with the motor. But the VFD is a great way to approach this situation. You can junk the starter to.
The Following User Says Thank You to J. V. For This Useful Post:
Jesse69 (07-08-2012)
Snapper Snow Blower Electric Starter Irishhusker Landscaping & Lawn Care 3 10-05-2012 04:37 PM
Starter course up the rake edge? rjniles Roofing/Siding 7 03-01-2012 07:29 AM
No starter strip used on shed roof install? waterskier_erie Roofing/Siding 4 10-31-2011 08:25 PM
scf starter wireing help needed rummins Electrical 6 06-20-2008 04:41 PM
CertainTeed starter shingle ? MACCC Roofing/Siding 2 04-20-2007 02:26 PM
