Compressor - Electrical - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 11:58 AM   #1
compressor
I took apart my pancake porter cable , and probably shouldn't have because now I can't remember which wire gets plugged in where. NOT AN ELECTRICIAN
Toolmaster is offline   Reply With Quote
Old 09-20-2009, 03:56 PM   #2
Rewards Points: 266
What was wrong with the compressor? (the reason you took it apart in the first place)
Wiring on the motor? Or the pressure switch?
junkcollector is offline   Reply With Quote
Old 09-20-2009, 07:46 PM   #3
That's simple.
That wire goes there, the second on goes there, and the third goes to that connection to the right. NOT A MINDREADER.
Seriously, we need more info if you are looking for an answer!
Willis
williswires is offline   Reply With Quote
Old 09-20-2009, 09:00 PM   #4
Registered User
Termite's Avatar
Originally Posted by williswires View Post
That's simple.
That's pretty funny!
Post some pics of what you're dealing with as well as an actual description and I bet you'll get the help you need.
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor Replacement Lawrence Coppar HVAC 1 06-30-2009 10:50 AM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 11:17 AM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Fridge compressor convert to air compressor? jogr Appliances 1 04-24-2008 01:10 PM
