Compatible Circuit Breakers? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-16-2012, 11:11 AM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by NJMarine View Post
Also in NJ final payment is not required until final inspection.
That completely discourages contractors from pulling permits. And what stops a homeowner from never calling in for an inspection? Is the contractor also notified?
Old 12-16-2012, 11:14 AM   #17
k_buz's Avatar
The permit fees have only been waived for replacing or repairing electrical services.
All other work require permits..
I do not believe that to be true from the stuff I've seen.
http://www.state.nj.us/dca/divisions...dy_fee_ltr.pdf
Old 12-18-2012, 09:43 PM   #18
Rewards Points: 58
He just added a generator inlet and the interllock kit (so I can't have the main and the generator circuits on at the same time)
cjdavia is offline   Reply With Quote
Old 12-18-2012, 09:45 PM   #19
Rewards Points: 58
Maybe that is what he did.. The previous owner of the house had been backfeeding the generator into the subpanel... the electrician I hired moved the backfeeding circuit to the main panel for the interlock kit...
Old 12-18-2012, 11:04 PM   #20
Rewards Points: 58
OK. I called Siemens... The Siemens guy agreed that the MH-T breaker should be fine although it has not been UL approved with my specific panel because the panel is just too old. It would void the warranty if the panel weren't 40+ years old but it should be safe. .
I did replace the mismatched GE breaker with an MP.
My electrician tells me that the newer tandem breakers don't utilize restrictive clips so they can go anywhere in the panel. The Siemens guy said that as long as it fits and I'm not overloading the board it should be fine. My panel is jammed with circuits for electric heat which we don't use anymore so I am sure we're not overloading it. The Siemens guy also tells me that this is not 2 separate 1/2 inch breakers (which were around in the 70s), it is technically a one inch tandem breaker so it is probably just fine.
Here is the thing. I asked my electrician to check out everything in the panel while he was there for the genny because the basement was smelling really funky -- like a dead fish. It seemed to be coming from the panel but I could not be sure. Of course he said everything looked fine, just like the previous electrician told me a month ago.
Before I replaced that GE breaker I heard the breaker for my water heater buzzing a bit. 10 minutes after turning off the main, the water heater breaker was still hot. I disconnected the wires and this picture shows what I found. The insulation on the wire seems nicely toasted. I trimmed the copper back a bit and installed a new breaker.. but I am wondering if I can trust that the wire is safe? The hot water heater is always running and I don't want to burn the house down!
Last night I also found another damned charred wire in the basement. This one was running along a floor joist. It looks like someone damaged it a long time ago with a staple. They removed the wire from the staple (probably by yanking on the wire) and just left both the staple and the wire there, the wire had a small cut and was badly bent. I'm not really sure what I am supposed to do. I peeled away the blackened insulation and charred ground-paper, then electrical-taped the tiny part of the hot wire that was exposed and arcing to the ground wire which now looks sorta oxidized.. Should I be running a new wire there?
Now I am going to vent a little.. sorry in advance. You can stop reading if you like. This is probably the 20th electrical issue I've found since I moved to this house and I'm about to lose it.
I've found inaccessible junction boxes hiding in the walls. If there is a metal box somewhere, I guarantee it is not grounded. I've grounded about 30 of them myself and it is not a fun nor rewarding job. I've found wires that are just nutted together inside of a wall cavity, not in any junction box at all. That is fun. Light fixtures that are screwed in and sit flush against the ceiling without a connection box or any barrier between the drywall and lightbulb, 100 watt bulbs when the maximum is 60... Funky electrical timers tucked away high up in the attic to control a flood light near the top of the roof because the previous owner was too lazy or stupid to install a switch in a place that made sense... Overloaded circuits everywhere. Improperly wired two and three pole switches. No GFCIs on the exterior outlets. Basement lights that just sizzle when you turn them on because the idiot has like 2 inches of exposed wire in there. Here is my favorite... Two pole switches that have been "modified" to become a one way switch for an outlet. Yes folks, when you walk into my kitchen in the dark and try to turn on the lights instead of touching a light switch you're sticking your finger in an outlet! My inlaws love that feature.... the list just goes on and on over here.
I have a young family here. 3 kids, 2 in diapers. I am really worried about the safety of this house.
It is impossible to find someone -- an electrician, a plumber, a carpenter, anyone at all that really cares and wants to do the job right -- use the right parts, look for other issues, etc.. even when I explicitly ask them to do it and say that I am willing to pay for their time.
I did take a residential electric course when I first moved here and luckily have experience with digital electronics so I am somewhat comfortable with these types of repairs, but not this magnitude, everyday something comes up. I'm at the end of my wits and have a day job to focus on. I can't spend all my time on this house. Sigh. Sorry to vent. I think it is time for a beer or something stronger I guess.
If you have any advice, I'm all ears!
Thanks in advance
Chris
Old 12-18-2012, 11:29 PM   #21
TTW
TTW's Avatar
Just curious, where are you located? Good idea to put it in your profile as codes vary greatly by location.
My house is over 100 years old and I am pretty sure is has some bit of every age of wiring in it. I feel your pain.
but I am pretty sure the plumbing was all redone and is up to perfect code!
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-19-2012, 01:56 AM   #22
" Euro " electrician
frenchelectrican's Avatar
Here my duex cents here.,
If your electrique water heater conductors is #10 AWG which they are larger than #12 et #14's if so that is legit size to use it but you may want to check little closer on the water heater itself to see if they are functing properly.
You should hear only one heating element is on at all ., If both are on then you have issue right there due if you have 4500 watts elements each and both are on the same time that is drawing 9000 watts that is way over the limit of the rating of #10 conductor without a question.
Unless you have seperated circuit for time of use like specal time period which the electrique rates are lower then the lower element is enabled ( turned on ) so that is one possiblty.
Now with second part is the MWBC with two pole one inch breaker which it is above the " water heater " space what that circuit run to ?? and I have a feeling that is not a " legit " MWBC ( Multi Wire Branch Circuit ) and you can have overloaded netural right there due it will be addtive like example you have 15 amp on one breaker and 20 amp on second breaker that can come up to 35 amp and that is way too much for #12 or #14 to take it.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
cjdavia (12-19-2012)
Old 12-19-2012, 06:55 AM   #23
Lic Elect/Inspector/CPO
I will reply to both your last posts. The contractor is responsible to call for inspections not the homeowner.
In the letter from NJ DCA is states thats municipalities MAY waive fees.
I am sure some have, but isome have not except for service repair or replacement.
NJMarine is offline   Reply With Quote
Old 12-19-2012, 10:11 AM   #24
Rewards Points: 58
TTW, Thanks so much for you post. I feel much better after seeing what you are dealing with :-) Our situation is not that different although I have NEVER seen anything quite like you've got in those photos! :-)
I live in CT and bought a house built in 1976, which is a 'new home' for folks like you and my folks in RI -- their house was built in the 1700s. I'm going to update my profile soon.
Thanks and good luck!
Chris
Old 12-19-2012, 10:36 AM   #25
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
The contractor is not responsible for calling for the inspection. He is responsible for obtaining the final inspection. Page 15 from this link reads;
Every licensee who performs or supervises work described in (a) above shall secure permits
when required and, within a reasonable time after completion of the work, secure an
inspection of the completed work when required to ensure conformity with the State Uniform
Construction Code Act, N.J.S.A. 52:27D-119 et seq., and its implementing rules set forth in
the Uniform Construction Code, N.J.A.C. 5:23.
Also, permit fees can be waived for repair work resulting from Sandy. It can be services and/or repairs to wiring. It is up to each individual municapality to decide.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 12-20-2012, 07:18 AM   #26
In order to obtain a final inspection some has to make a call to schedule the inspection. Some town only want the contractor to call, because to many times the homeowner called and the work done was not ready for inspection.
I am only refering to the area that I do work and what I need to do.
To clarify about permits fees being waived, some towns have done that but permits still need to be issued. I live in the shore area that was hit. I have not had to pay for permits that were for service repair or replacement, which includes panels. I have had to pay if wiring had to be replaced.
Circuit Finder and Tandem breakers?? Skelleyman Electrical 7 10-22-2012 03:06 PM
Main circuit breaker's screws hot even with breaker off? darlingm Electrical 13 01-15-2012 12:44 PM
Outlets on 2 circuit breakers? travesty Electrical 8 04-05-2011 10:19 PM
2 breakers / 1 circuit dn100 Electrical 3 10-03-2010 09:01 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 01:34 PM
