Common To Ground On Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 09:21 PM   #16
joed's Avatar
Rewards Points: 13,358
Originally Posted by Gac66610 View Post
Hard to tell, my eyes aren't what they use to be, but it looks like the brass tab between the screws is missing.
I can't really see it but that would explain using the ground to make up the possible missing neutral I mentioned post #10.
Old 01-14-2013, 01:12 PM   #17
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Saw it in Camden all the time. Perfect example of what a trunkslammer or amature will do. Illegal and dangerous as hell. Check the entire house or hire an electrical contractor to do it for you.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 01-15-2013, 08:33 PM   #18
DBW
Originally Posted by Jim Port View Post
They can share the same bar in a service panel.
Didn't know that.... thanks.
Is it ok to split them in a service panel?
I did this when I put in a larger panel a few years ago.
DBW is offline   Reply With Quote
Old 01-15-2013, 08:38 PM   #19
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
As long as they are bonded at the first point disconnect.
The Following User Says Thank You to jbfan For This Useful Post:
DBW (01-15-2013)
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
How to ground a 2-wire outdoor lamp post elect. outlet numbersguy Electrical 4 09-23-2012 08:06 AM
ground bathroom outlet flman Electrical 4 01-16-2011 11:52 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
