Commercial Inside Wall Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 02:26 PM   #1
Commercial Inside wall wiring
Hi all,
I need to run Siamese cable RG59/18-2 for security cameras in a commercial environment. I am wondering if it needs to be cl2, cl3, cmr? I wont be going thru a plenum ceiling, so I know I won't be needing plenum.
Thanks for all the help.
helpless handyman is offline   Reply With Quote
Old 07-06-2012, 04:14 PM   #2
Rewards Points: 6,652
It is a commercial job, your local AHJ will tell you what they require. Also some areas require the person doing to job, to not only pull a permit, but also be licensed and bonded.
Old 07-06-2012, 06:02 PM   #3
You just have to love these responses!!
I thought this forum was to help out DIY? I am just asking a simple question on types of cabling, feels like I'm taking your job!!!
Thanks!
Old 07-06-2012, 06:08 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks!
Yeah, and DIY is only for 'your' house not a commercial building, sorry you don't understand that.
Old 07-06-2012, 06:22 PM   #5
Thanks guys
Old 07-06-2012, 06:22 PM   #6
This is not a DIY job. It is a commercial structure as you mentioned, which means licensed professional and permit pulled.
Old 07-06-2012, 06:23 PM   #7
E2 Electrician
Thanks guys
No problem! BTW, you could always just do the required courses and on the job training, achieve your license in the electrical field and then answer your own question. and then feel the same way we do when you come across a DIY forum and ask a question about a commercial application. just saying.
The Following User Says Thank You to stickboy1375 For This Useful Post:
LooseSCruz (07-06-2012)
Old 07-06-2012, 07:52 PM   #8
Master Electrician
if it's his own business he can install it depending on the state he lives in as long as it doesn't notify the police. I somehow doubt this is the case here though. Apparently security systems don't fall under electrical work. Most likely will have to pull a permit either way though.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-06-2012, 08:35 PM   #9
E2 Electrician
Security systems certainly do fall under the NEC...
Old 07-06-2012, 09:07 PM   #10
Missouri Bound's Avatar
Hi all,
Is this an existing building or new construction? If it's new it should be spec'd somewhere unless it's an addition. If it's existing, the AHJ just may be the right place to go. Is cost the issue here?
Do you want it your way or the right way?
Old 07-06-2012, 09:13 PM   #11
Okay guys, lets just drop this already!
Thanks anyways
Old 07-06-2012, 10:09 PM   #12
Master Electrician
yes they are in the NEC, no you don't have to be an electrician to install camera's
i should have said they don't fall under an electrical license instead of electrical work.
I'm not sure where i said they weren't covered in the code.
Old 07-06-2012, 10:18 PM   #13
E2 Electrician
My mistake, I misread what you actually wrote.
Old 07-06-2012, 11:47 PM   #14
Sorry, but there are some areas, that you have to be a licensed electrician to work on LV systems. And even better, is if it is a union job, you would never be able to do the work, because the union would never let a non-union business on site.
Yes, it is about a money grab, but also about doing things correct, is why some areas want a company to be bonded and licensed, no matter what the job is, or who is doing it.
Old 07-06-2012, 11:50 PM   #15
Hmm...using "even better" and union job" in the same sentence seem like a contradiction.
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
jbfan (07-06-2012), stickboy1375 (07-06-2012)
Structured Wiring Panel Location...Fire Rated Wall??? RICKM15752 Electrical 0 04-20-2011 12:30 PM
Tv wall mounted wiring? cklesta Electrical 2 03-15-2011 10:53 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
