Commercial Inside wall wiring
Hi all,
I need to run Siamese cable RG59/18-2 for security cameras in a commercial environment. I am wondering if it needs to be cl2, cl3, cmr? I wont be going thru a plenum ceiling, so I know I won't be needing plenum. Thanks for all the help. |
It is a commercial job, your local AHJ will tell you what they require. Also some areas require the person doing to job, to not only pull a permit, but also be licensed and bonded.
You just have to love these responses!!:thumbsup:
I thought this forum was to help out DIY? I am just asking a simple question on types of cabling, feels like I'm taking your job!!! Thanks! |
Thanks guys:thumbsup:
This is not a DIY job. It is a commercial structure as you mentioned, which means licensed professional and permit pulled.
if it's his own business he can install it depending on the state he lives in as long as it doesn't notify the police. I somehow doubt this is the case here though. Apparently security systems don't fall under electrical work. Most likely will have to pull a permit either way though.
Is this an existing building or new construction? If it's new it should be spec'd somewhere unless it's an addition. If it's existing, the AHJ just may be the right place to go. Is cost the issue here? |
Okay guys, lets just drop this already!
Thanks anyways:thumbsup: |
i should have said they don't fall under an electrical license instead of electrical work. I'm not sure where i said they weren't covered in the code. |
Yes, it is about a money grab, but also about doing things correct, is why some areas want a company to be bonded and licensed, no matter what the job is, or who is doing it. |
Hmm...using "even better" and union job" in the same sentence seem like a contradiction.:laughing: |
| All times are GMT -4. The time now is 03:17 PM. |
