#1 |
comm lines near power lines
I'm building a house. I am digging a trench for conduit and preparing an entrance for wires into the house. Can communications lines like for Verizon telephone/internet/cable tv share the same trench (separate conduit of course)? Can they share the same entrance into a house?
#2 | |
comm lines near power linesQuote:
If in separate conduits-yes. Same entrance means what? |
#3 |
I'm building a house out of ICF blocks. ICF (insulated concrete form) blocks are styrofoam blocks with concrete poured into the core. Same entrance means I inserted a 2" pvc conduit through the styrofoam before the concrete pour. Once the concrete pour is done you can't make 2" holes into the walls easily. So I have a 2" entrance through which all wires will enter the house.
#4 |
comm lines near power lines |
#5 | |
230.7 Other Conductors in Raceway or Cable. Conductors other than service conductors shall not be installed in the same service raceway or service cable. |
#6 |
100A service actually and the main breaker will be outdoor. The conduit going into the house will be occupied by 14/2 and 12/3 cables. Does this rule still apply?
#7 |
E2 Electrician
More than 3 current carrying conductors and you have to start derating your wires, this may or may not affect your specific outcome.
#8 | |
E2 Electrician
This is what I would do, from the meter location, run a 2 or 3" conduit for power, 2" for Telephone, 2" for catv, and a spare 2" for future items... |
#9 |
Electrical Contractor
2" seems a little large for a line that will be max 3/8"
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe. |
#10 |
E2 Electrician
Possibly, but around here, its what the utility requires, if the demarc location is at the meter, then he can certainly can use whatever size conduit he wishes, but if the utility is supplying the wire and doing the termination, its required to be 2" minimum...
Funny thing is that the cable company used to make us install 3". And if you never pulled wire before, you will never understand how much easier it is with a larger sized conduit... conduit is cheap anyway.
#11 |
Verizon wanted 2" conduit on my ranch. But I think you guys are confusing something here. You're talking about conduit going from the Verizon handhole on the edge of the property near the road to the house. Then there's a Verizon box on the wall of the house that converts their thick wire into tiny little CAT5 wires. The CAT5 wire is what goes into the house from outside. The CAT5 wire will fit into a 1/2 or 3/4" conduit.
#12 | |
E2 Electrician
| Display Modes | |
| solar power - how to hook up and how to get PAID? | MLMIB | Electrical | 7 | 11-03-2011 02:21 AM |
| Dishwasher Power Supply | Captain.Sassy | Electrical | 14 | 09-14-2011 06:28 AM |
| Wring for Lincoln Power Mig Welder | vstoyko | Electrical | 17 | 01-15-2009 07:15 PM |
| Problem W/ Power after Switching Outlets... | G19-Fanatic | Electrical | 17 | 08-28-2006 02:55 PM |
| Partial power on same fuse! | joyjam | Electrical | 5 | 07-10-2005 11:23 PM |
