Combo Switch Recept?? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 09:00 PM   #1
Rewards Points: 730
Ok, I'm a bit unsure of this, so figure I'd better ask.
I'm trying to wire up a levitron combo switch/receptacle. The goal is to switch the receptacle so that I can turn on/off a radiant heater I plan to plug into the device. Nothing else will be in-line with the switch or the receptacle.
I have the black(hot), white(neutral) and ground wire coming into the junction box and no other wires. I'm finally thinking I wire the black wire to the brass terminal, which is next to the switch, and the white wire to the silver terminal, which is next to the receptacle. Obviously, the ground goes to green grounding screw. What about the two black terminals??? If I'm correct on the rest, do I just leave them alone with nothing connected? The jumper bar is in place.
....or am I totally wrong? If so, please advise...I've done this before, but it's been a while.
Thanks!!
Master Brian is offline   Reply With Quote
Old 03-17-2013, 09:10 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 488
Model of the device?
jbfan is online now   Reply With Quote
Old 03-17-2013, 09:31 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Is the device you are replacing a switch or a receptacle?
Coastal South Carolina
Old 03-17-2013, 10:40 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Thanks!!
You are correct wiring as you describe will switch the receptacle on and off so long as your combination device is not replacing a switch that is on a switch loop where the white is a hot wire. In other words if your replacing a switch with your combo device and all the wires that you have in the box are black,white and ground no other wires then you do not have a neutral and the receptacle will not work.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-17-2013, 11:10 PM   #5
Rewards Points: 730
The model is T5225. It is not replacing anything, it is being added and fed from another receptacle.
Old 03-18-2013, 06:00 AM   #6
Rewards Points: 2,516
As wired below, the receptacle is controlled by the switch.
hammerlane is offline   Reply With Quote
Old 03-18-2013, 10:45 AM   #7
Rewards Points: 730
So, my thoughts are correct! Thanks!!!
Old 03-18-2013, 04:49 PM   #8
Rewards Points: 730
And it works, now if my heater would get here!
Thanks again!!
3 way switch layout has me confused crescere Electrical 5 09-08-2012 10:26 AM
Fan/light wiring from 2 switches to combo switch dbinaz Electrical 2 08-06-2012 01:51 PM
help with light/outlet switch combo aftermath431 Electrical 5 07-06-2012 11:23 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
