Combo Heat Lamp/exhaust Dying - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2012, 09:37 PM   #1
Rewards Points: 2,192
combo heat lamp/exhaust dying
I discussed previously how surprised I was to see heat lights in Florida. Also that one exhaust fan wasn't working.
Now, after spending more time in this newly purchased house I realize I have combo heat light & exhaust.
The 2nd one is terribly noisy like a Boeing 747 landing. The house is 29 yrs old so I think these are original.
I plan to measure the openings, buy 2 exhaust (skipping the heat lights) and have an electrician install them.
Am I going to run into too many selections? Is there anything special to look for when buying exhaust fans? thanks
Startingover is online now   Reply With Quote
Old 06-02-2012, 09:41 PM   #2
Should be an easy switch out. Regardless I'm sure you will have to patch.
dwellselectric is offline   Reply With Quote
The Following User Says Thank You to dwellselectric For This Useful Post:
Startingover (06-02-2012)
Old 06-02-2012, 10:01 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm not sure you will even have to patch. Many fans that were produced 30 years ago, are still being produced (with some minor design changes) today. Look for a model number inside the housing.
The Following User Says Thank You to k_buz For This Useful Post:
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
