Old 05-03-2010, 09:56 AM   #1
Combination switch and outlet
bought a combination switch/outlet for my ceiling ( pool table light )..new construction basement..there is a pull chain light there with just the 3 wires ...I want to power the outlet by the switch ....threw the box out no instructions ..do I have the right switch.. how do I wire ..thanks
44070dart is offline   Reply With Quote
Old 05-03-2010, 10:36 AM   #2
Just call me Andrew
What is the make/model of the switch? Can you take a picture?
Andrew
secutanudu is offline   Reply With Quote
Old 05-03-2010, 11:12 AM   #3
I assume you are talking about a switch combo something like what is shown here: http://www.homeadditionplus.com/Elec...bo_Circuit.htm
I also assume you have a white, black, and bare wire for your three wires.
While I don't have a switch like this in hand to review, I would think the way to wire it (based on looking at the front of the device as shown in the picture above), the bare wire goes to the ground screw near the bottom. The black (hot) wire should go to the top left terminal next to the switch. The two terminals on the right should be wired together. The white (neutral) should go to the bottom left terminal next to the receptical. That way, the switch provides switched power to the HOT of the outlet, with the outlet always properly connected to neutral.
The basic idea is to have the hot (black) of the outlet to be supplied from the switch (you want to make sure the neutral isn't switched, because if you do, the setup will still work, but the situation is dangerous because power would still be supplied to the lights/outlet when the switch is off).
HooKooDooKu is offline   Reply With Quote
Old 05-03-2010, 03:51 PM   #4
joed's Avatar
You are going to need a 14/3 cable(black, red, white bare).
At the ceiling light.
disconnect the light wire from the black. Connect it to the new red wire.
Connect t he new black to the old black.
Connect the new white to the old whites.
At the switch.
Connect the black to the double gold screw on one side. Tis is common power to the switch and the receptacle.
Connect the red to the single gold screw on the other side.
Connect the white to the single silver screw on the other side.
Connect the bare to the green ground screw.
Do not PM with questions that can be asked in a forum. I will not respond.
The Following User Says Thank You to joed For This Useful Post:
44070dart (05-03-2010)
Old 05-03-2010, 08:00 PM   #5
thank you gentlemen
Switch outlet in bathroom odale Electrical 7 12-11-2009 08:04 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 09:08 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 06:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
