Old 04-05-2011, 11:05 PM   #1
Combination AFCI's keep tripping
New construction. 320 service. 3 AFCI's keep tripping in panel A. Panel B no AFCI's are tripping. Hooked up an AFCI tester from Siemens. No load, and the tester still has a reading that there is a load or a problem (ie nuetral to ground). Tested contunuity nuetral to ground no problem there. Swapped out old AFCI's to brand new AFCI's and still trips. Switched the circuit to the other phase and reads fine and does not trip. Regular breakers do not trip. I have come to the conclusion that there is a bad phase from the street to the service. Just curious if anyone else has had such a problem or heard of this. Stupid AFCI's. Thanks.
fullnelson is offline   Reply With Quote
GFCI problems...replacing an old one...now tripping. ams4life Electrical 7 06-17-2010 07:10 PM
Trace sw4024 inverter compatible with AFCI's??? Kent C Electrical 3 05-29-2010 04:17 AM
New home AFCIs tripping geezer Electrical 18 01-14-2010 03:30 PM
Dead Breaker? and Nusiance Tripping... jasonblu Electrical 9 11-06-2009 07:13 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 02:47 PM
