Coloring A White Hot? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 08:46 AM   #1
Coloring a white hot?
While having a look in my panel I noticed it looks as though the white wire of a couple of 10-2 romex wires were painted or colored black. Looks like sharpie to me. They are both connected to 2-pole breakers. Were these supposed to be 10-3 wires?
It's not letting me upload the image...
MisterSteve is offline   Reply With Quote
Old 02-23-2012, 08:58 AM   #2
Not necessarily, what you see is most likely a 240v circuit where the white wire was reassigned, painted or taped red or black to indicate hot. This is code and would be done in a 30amp 240v circuit such as for an electric hot water heater.
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Hardway is offline   Reply With Quote
Old 02-23-2012, 09:16 AM   #3
joed's Avatar
Rewards Points: 13,762
Many devices like water heaters or baseboard heaters only need two wires. A 10/2 is used and the white is coloured to indicate it is hot. Normal practice and code compliant.
Old 02-23-2012, 09:51 AM   #4
OK, No worries then. Water heater and heat pump on each one. Just thought wires couldn't be re-identified if 6awg or smaller and that it was at least preferred to have 4-wire for large appliances. All other 2-poles are 4-wire in the panel, that's what raised my eyebrows. Thanks!
Old 02-23-2012, 10:39 AM   #5
Rewards Points: 1,548
For wires #6 and smaller, colored wires may not be remarked white for neutral, and wires may not be remarked green for grounding.
Old 02-23-2012, 10:42 AM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 654
True, but this does not include cable assemblies, which romex is.
jbfan is online now   Reply With Quote
Old 02-23-2012, 12:55 PM   #7
I recently saw a service update and the licensed electrician used green # 6 from panel to ground rods, but from the panel to the meter #6 black taped green at the meter and panel. Permit and inspected, passed.
Old 02-23-2012, 02:23 PM   #8
jbfan's Avatar
Rewards Points: 654
I'm sure that is one code violation that happens many times.
I can't tell you how many times I have taped the wires.
Old 02-23-2012, 02:33 PM   #9
When did it become code that you can't reassign #6 single conductors? Maybe not all venues are following it. Or electricians are using what they have on hand
I have to run ground from 100 amp main to water meter and install ground rods when I change out current galv water line.
Ceiling Paint White versus Wall Paint White David Riley Drywall & Plaster 1 01-13-2011 09:16 AM
basic white paint mcl6302 Painting 6 10-11-2010 04:58 PM
turning white to antique white rustyedge Painting 6 10-01-2010 12:08 PM
What color to paint existing white kitchen cabints with white appliances lisa.webb Painting 5 07-06-2009 06:03 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 07:54 AM
