Color Sheath On Romex/NM Cable? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2009, 04:47 PM   #1
Color sheath on Romex/NM cable?
My house was built in 1999 and all the wiring through the home other then to the AC and stove is 12/2 or 12/3 Romex. All of it is white sheathed. But when I went to Home Depot to buy more 12/2 all they have is yellow sheathed 12/2 and the 14/2 is white. I then checked my local Carter Lumber and they had the exact same thing, 12 is yellow and 14 is white.
Did they stop selling it all in white so it's easier to tell the difference? I guess it doesn't matter but I wanted to make sure before I buy some. Can I still find white 12/2 and 12/3 to maintain uniformity with what is already installed?
vseven is offline   Reply With Quote
Old 12-20-2009, 04:51 PM   #2
300zx's Avatar
Yes 12-2 was white and black check the lettering on the wire.1999 i think was white
300zx is offline   Reply With Quote
Old 12-20-2009, 05:32 PM   #3
Licensed electrician
Rewards Points: 1,020
I have not seen white #12 NM for several years. There is no issue with the different color sheath. It does not need to match the older cables.
Old 12-20-2009, 05:50 PM   #4
I was hoping to buy the same but doesn't sound like they make 12/2 in white anymore. Yes I'm positive its 12ga...the smallest breaker in the box is a 20A and I've checked the wire are multiple places throughout the house with them all saying 12. It's not a big deal for new runs but I was trying to match the old for some extensions (like I have a pull string on a light so I'm going to just put a switch in between and a regular light base....just will look goofy with a 6' piece of yellow with whites going into the junctions in the middle).
Thanks for the quick answers.
Old 12-20-2009, 06:19 PM   #5
Rewards Points: 1,016
Am I understanding correctly that the romex is exposed where it can be seen? Typically that's a no-no, except for example in a garage with open framing.
Old 12-20-2009, 06:26 PM   #6
joed's Avatar
Rewards Points: 11,568
It is not a code issue yet but has become a sort of industry standard for different gauges to be different colours.
Old 12-20-2009, 06:56 PM   #7
No romex is exposed in the house....this is down at my breaker box. And the place where I'm looking to add a switch in is in my unfinished basement where I can see all the romex runs also. So since I was adding to I was hoping to stay the same color but it's really not a big deal I suppose.
Old 12-20-2009, 06:59 PM   #8
Electrical Contractor
kbsparky's Avatar
You can always paint the stuff, if you really don't like the yellow.
-KB
Old 12-20-2009, 07:05 PM   #9
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
no you can't. That may harm the insulation and is not legal.
Old 12-20-2009, 07:06 PM   #10
hahaha....no I don't care that much. In all honestly once I put up drywall I'll never see it again other then at the breaker box. And even then I hope I'm not checking my breaker box very often....
Old 12-21-2009, 05:17 AM   #11
kbsparky's Avatar
Got a Code reference to back up this claim?
-KB
Old 12-21-2009, 07:29 PM   #12
nap
You talking to me?
nap's Avatar
try 110.11 but there are others.
Old 12-21-2009, 07:59 PM   #13
110.11 refers to deteriorating agents
Is that the right section ?
If so I guess it would depend upon the paint
I think it may also depend upon when it is painted
I'd never paint anything before Inspection
But I have seen plenty of NMB painted the color of a basement wall
Old 12-21-2009, 08:01 PM   #14
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
How about a code reference for this one?
Since when is "exposed" NM cable a violation?
What about 334.15?
Speedy Petey is online now   Reply With Quote
Old 12-21-2009, 08:57 PM   #15
nap
You talking to me?
nap's Avatar
the basis is: you cannot put anything on the wire that would cause it to deteriorate. Unless you can prove (like in UL listing) that what ever paint you are considering putting on the wire will not deteriorate it, you must consider it as not acceptable.
It may have done nothing but unless you can prove it is acceptable, it is not acceptable.
Need Advice Old Metal NM Cable Anchors bltglt507 Electrical 15 12-18-2009 05:31 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
Satellite vs. cable coaxial types? Badfish740 Home Theater 6 02-17-2009 12:00 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
