Old 08-05-2011, 08:12 PM   #1
Color Code 12/2 wire help
I have this wire: , but the only difference is, mine is a light blue, but it is still 12/2 600 volts. What is the difference?
joshua_r_86055 is offline   Reply With Quote
Old 08-05-2011, 08:17 PM   #2
I=E/R
a7ecorsair's Avatar
Does your wire say it is NM-B? It will be printed on the sheathing and the package.
a7ecorsair is offline   Reply With Quote
Old 08-05-2011, 08:18 PM   #3
It sure does
Old 08-05-2011, 08:20 PM   #4
I=E/R
a7ecorsair's Avatar
Originally Posted by joshua_r_86055 View Post
It sure does
Then the wire in the picture is yellow and your wire is blue.
The Following 2 Users Say Thank You to a7ecorsair For This Useful Post:
J. V. (08-06-2011), Speedy Petey (08-05-2011)
Old 08-05-2011, 08:22 PM   #5
yes, seems to have the same ratings, etc, as the yellow wire, just wondering, if the color had anything to do with the code?
Old 08-05-2011, 09:38 PM   #6
Electrical Contractor
kbsparky's Avatar
The Code does not mandate any color scheme for the outer jackets of type NM cables.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
joshua_r_86055 (08-05-2011)
Old 08-05-2011, 09:40 PM   #7
that's all I need to know, must be why I couldn't find it, lol. Thanks a lot
Old 08-06-2011, 12:48 PM   #8
J. V.'s Avatar
Are you in the US?
Old 08-06-2011, 02:03 PM   #9
zpm
yeah, right
I bought some light blue 12/2 wire in the 90's.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 08-06-2011, 02:20 PM   #10
it does seem slightly faded in spots, so that could be the time period it is from
Old 08-06-2011, 02:21 PM   #11
Originally Posted by J. V. View Post
Are you in the US?
yes I am
Old 08-08-2011, 05:37 PM   #12
I was told in canada the blue cable is generally used for AFCI bedroom circuits but its not code or anything..just a way to try and get you to buy more wire :P
MitNotrof is offline   Reply With Quote
Old 08-08-2011, 06:11 PM   #13
lolll, well i'm not falling for it
Tags
12/2, blue, color code, house wiring, yellow
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 07:41 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
6/3 wire through smurf tube? anygren Electrical 13 08-14-2010 08:23 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
What type wire to use from transfer switch to outdoor outlet brjl Electrical 7 12-02-2009 04:35 PM
