-   -   Coincidence? (http://www.diychatroom.com/f18/coincidence-151761/)
rusty baker 07-27-2012 10:11 PM
Coincidence?
My breaker box is about 15 years old. Last night about 7 pm, the lights went out. The main breaker wouldn't click off or on. Changed it this morning and it has been fine since then. Anything to worry about or breaker just getting old? What do you think?
dmxtothemax 07-28-2012 12:16 AM
What brand of box/panel was it ?
How did the rest of the box look ?
Was it burnt looking ? rusty/corrodded ?
Need lots more info !!!
jlmran 07-28-2012 12:18 AM
Did only the lights go out or did other things go out also?
kbsparky 07-28-2012 12:59 AM
It could have taken a hit from lightning or other large surge.
Those things should last much longer than 15 years, unless a catastrophic event took `em out.
rusty baker 07-28-2012 11:40 AM
The rest of the box looks fine. The breaker looked OK. Not burnt or anything. Just would not flip to off or on. It was the main breaker, everything went out. We had a lightning strike a couple months ago that took out our sump pump, computer modem and answering machine.
wirenut1110 07-28-2012 11:55 AM
Probably Crouse-Hinds, Murray, or Bryant. Sounds like something they're good for.:yes:
bobelectric 07-28-2012 11:59 AM
I changed a Sq.D last month. Something said about operating them once a year,at least.
wirenut1110 07-28-2012 12:03 PM
As much as we've lost power in the last year, mine definitely is getting a work out:thumbup:
rusty baker 07-28-2012 02:48 PM
No opinions?
brric 07-28-2012 06:26 PM
If a replacement main is readily available have it changed out and be done with it.
rusty baker 07-28-2012 06:29 PM
I did change it. Just wondering why it would quit working.
jlmran 07-28-2012 06:56 PM
Nothing lasts forever...but God.
Canucker 07-28-2012 09:24 PM
I would hope his breakers are more reliable than that :eek:
Missouri Bound 07-28-2012 10:03 PM
Originally Posted by rusty baker (Post 976244)
No opinions?
Get an ammeter and check the loads on your main. When they overheat they tend to fail...maybe you are a bit heavy on your load. Check it when everything you normally run is on. What's the amperage of that breaker? Do you have central air? Judging from your location it's been 100 degrees there (and here) for quite a while now.
k_buz 07-28-2012 10:09 PM
Since it has been changed out, I would sleep tight. If it happens again, I would start looking farther into the issue.
