Code Violation? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 06:25 PM   #1
Rewards Points: 154
Code violation?
Is there a code violation in this wiring? This is in a large crawl space that I only use for storage. None of the wires are stapled to the lower edges of joists. They are #12 and #14 wires going to lights and outlets.
ovahimba is offline   Reply With Quote
Old 12-12-2010, 10:36 PM   #2
" Euro " electrician
frenchelectrican's Avatar
There is couple items it kinda bother me and what kind of vent pipe is that dryer vent or other ??
Second it need to staple the NM better { I rather bore the joinst and run the cable thru that is my prefered methold }
What room this served??
Merci,.
Marc
Old 12-13-2010, 10:13 AM   #3
Rewards Points: 154
Thanks for the response. That is a dryer vent. Above it to the right is the main panel. The room above and away is the garage. I added some circuits for some lights and outlets in the crawl space.
If that corner didn't have so much piping and there was a possibility of adding living space there in the future, I probably would have threaded the wiring through the joists and studs.
Code Violation? rdtour Building & Construction 9 01-16-2010 10:31 AM
Sold condo just realized it had a code violation Dave0009 Electrical 41 12-06-2009 07:45 PM
Lights in same joist space with water pipes - Code violation? jweller Electrical 2 03-15-2009 01:02 PM
Building code violation fetzo Building & Construction 18 03-22-2008 02:42 PM
code violation? krw1957 Electrical 6 12-11-2007 06:16 AM
