Is This A Code Violation? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 01:45 PM   #1
Is this a code violation?
This is an old Square-D split-bus panel type QO-20-4120, rated for 100 amps. House itself has 100 amp service at the meter. However, if you add up the ratings for the top 6 "disconnecting means" breakers, you end up with more than 100 amps. Theoretically, this setup could draw more than 100 amps.
Obviously, most split bus panels themselves are no longer legal (408.36 exception 1) but this panel would be grandfathered in I believe.
kwilcox is offline   Reply With Quote
Old 09-02-2013, 01:59 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
No, it's not a code violation. That is NEVER a way to figure the load on the panel.
Hell, if you add up the breakers that's on the 60 amp breaker feeding the lower half, it's more than 120 amps.
wirenut1110 is offline   Reply With Quote
Old 09-02-2013, 02:31 PM   #3
I like that answer and guessed that would be the case here.
What bugs me however, is that the lower breakers in the example you cite can't collectively draw more than the rating of the top breaker that protects their feeder. Not the case for the top 6 breakers which can collectively draw more than 100A.
What protects the meter base (rated for 100A) and the feeder from the base to the panel as well as the panel itself?
Old 09-02-2013, 02:41 PM   #4
Rewards Points: 510
Nothing really 'cept the POCO's fuse, which ain't gonna happen...lol
Probably one of the reasons they're not allowed anymore but, I wouldn't worry about it.
The Following User Says Thank You to wirenut1110 For This Useful Post:
kwilcox (09-02-2013)
Old 09-02-2013, 02:42 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Again, adding up the breakers is a completely meaningless number. You also have to consider, adding up 120V single-pole breakers is not any kind of comparison to the 240V feeder breaker at the top. To make that useless comparison you'd have to add up all the 120V breakers and divide them in half....which is totally not worth even doing.
Nothing. The breaker on the utility transformer really.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
Old 09-02-2013, 06:28 PM   #6
Thanks for the replies guys!
Code violation? ovahimba Electrical 2 12-13-2010 10:13 AM
Carrier Error Code 33 russell124 HVAC 4 12-04-2010 07:19 PM
Canadian Electrical Code Question flemingetq Electrical 4 11-25-2010 09:42 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Building code violation fetzo Building & Construction 18 03-22-2008 02:42 PM
