Code For Smoke Detector - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2011, 08:31 PM   #1
Code for smoke detector
What is code requirement for location of hard-wired bedroom detector on bedroom ceiling with 8/12 pitch How close to highest point on ceiling and how far from wall?
user108902 is offline   Reply With Quote
Old 03-21-2011, 08:35 PM   #2
Rewards Points: 558
read this post from stubbie:
This is pretty close for all parts of the country. Taken From the US home inspectors website
Where to Place the Detectors
It is important to properly place the smoke detectors in the home. In most locations throughout the U.S., smoke detectors are required in all new homes. The number and location are listed below:
Number and Location Requirements
  • The minimum standard as stated in the National Fire Prevention Association's National Fire Alarm Code (NFPA 72): There should be a smoke detector on every level of the house, including the basement and outside every bedroom.
  • New homes require hard-wired alarms to be interconnected so that if one alarm is activated, all alarms will sound the alarm signal.
  • New homes require smoke detectors in every bedroom.On floors without bedrooms, smoke alarms should be installed in or near living areas, such as family rooms and living rooms.
Placement Requirements
  • As stated by the NFPA: "Since smoke and deadly gases rise, alarms should be placed on the ceiling at least 4 inches from the nearest wall, or high on a wall, 4-12 inches from the ceiling. This 4-inch minimum is important to keep alarms out of possible "dead air" spaces, because hot air is turbulent and may bounce so much it misses spots near a surface. Installing alarms near a window, door or fireplace is not recommended because drafts could detour smoke away from the unit. In rooms where the ceiling has an extremely high point, such as in vaulted ceilings, mount the alarm at or near the ceiling's highest point."
Additional Guidelines for Installation
  • If you sleep with your bedroom doors closed, it is recommended that a smoke detector be installed inside each bedroom. Alarms should also be installed in other areas of your home where people sleep.
  • Wired systems should not be connected to a circuit that could be turned off with a wall switch.
  • Plug-in systems should have a restraining device at the outlet to prevent the plug from accidentally coming loose.
  • Hard-wired systems should be installed by a qualified electrician.
  • Do not install the smoke detector near windows, doors or forced-air registers where air flow would interfere with the operation of the detector.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
user108902 (03-21-2011)
Old 03-22-2011, 11:50 AM   #3
Rewards Points: 3,130
You mention hard-wired detectors a couple of times, but I don't think you make the point that in new construction, hard-wiring is a code requirement. You cannot use detectors that are just battery powered.
Old 03-22-2011, 12:56 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I have to disagree with the "highest point" in a room with a vaulted ceiling.
check out the diagram at this link
http://www.springfieldfirema.org/for...ction-form.pdf
there is a dead air space at the peak. You need to be within 3 feet of the peak. The diagram shows 4" in vertical height from the peak minimum. Typically I have used 12" linear measurement from the peak as desirable. Depending on the the angle of the ceiling, it results in about the same placement.
Old 03-22-2011, 01:29 PM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
No mention of CO detectors in Stubbie's post? Is that a Massachusetts only thing?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-22-2011, 02:04 PM   #6
Rewards Points: 558
You would have to contact Stubbie and ask him about thatů
Old 03-22-2011, 02:21 PM   #7
You need at least one carbon detector on the second floor. depending on how long the hallway is and where bedrooms are located you may need two. You need to add a carbon on the first floor if there is a bedroom on said floor. As for the smoke on a vaulted celing I normally put mine a foot off the highest point of celing as smoke rises up obviously.
jerseystyle26 is offline   Reply With Quote
Old 03-22-2011, 02:54 PM   #8
Rewards Points: 320
I would check with your AHJ for smokes and co placement. We require co's on every habitable level.
teamo is offline   Reply With Quote
Old 03-22-2011, 02:59 PM   #9
It varies state by state, normally its how I stated originally.
Old 03-22-2011, 04:45 PM   #10
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
It is not just a Massachusetts law. I believe at this time half the country requires CO detectors.
HIVOLT is offline   Reply With Quote
Old 03-22-2011, 05:28 PM   #11
Nah whole country requires it its code
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
Smoke detector in garage? BlueBSH Electrical 6 03-18-2010 02:57 PM
motion detector wiring (alarm systems) WendyS Electrical 3 02-25-2010 10:39 PM
Motion Detector For Compact Florescent Bulbs Jazan Electrical 2 10-20-2009 09:12 PM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
